 hitec servo voltage >
hitec servo voltage
hitec servo voltage
Old 11-10-2012 | 08:40 AM
Default hitec servo voltage
what is the voltage range for hitec hs-635hb, need to buy reciever batt want lipo 7.4 volt spectrum rec ar7000 high voltage is 9.1 volt.servo spec 4.8 to 6.0 volt.im not sure if I can use this batt with this servo.
Old 11-10-2012 | 08:55 AM
speedracerntrixie's Avatar
My Feedback: (29)
Default RE: hitec servo voltage
I wouldn't run much more then 6V on any servo that is not designated high voltage. No my race planes that I want to run lithium batteries on I just throw in a regulator made by Team Losi, It is small, light and delivers plenty of power.
http://losi.com/Products/Features.aspx?ProdId=LOSB9608
Old 11-10-2012 | 10:17 AM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Don't use a battery with that high of a voltage inside the plane. It can, and more than likely will, cause problems with your receiver and servos. If you want to use a battery with that high of a voltage then you need to use a voltage regulator to drop the voltage down to what the radio gear can handle.<div>
</div><div>Ken</div>
Old 11-10-2012 | 05:31 PM
Ditto what those guys said. You could use 2s Li-Fe, but I wouldn't use unregulated Li-Po.
Old 11-10-2012 | 06:51 PM
DavidAgar's Avatar
My Feedback: (108)
I use 3 cell Lipo's in my planes with a Castle Voltage Regulator that keeps the reciever voltage at 5.8 volts. The regulators are adjustable. As mentioned, it is not a good idea to go over 6 volts. Good Luck, Dave
Old 11-10-2012 | 07:31 PM
Moderator
2 cell LiFe is fine, but not Lipo. the voltage ratings in the servo specs are for the nominal voltage of the packs ie, a 6v NiCd. That pack comes hot off the charger around 7.2v, while the LiFe starts around 7.4v. That's close enough to not hurt anything.
Old 11-11-2012 | 06:45 AM
Remember, the higher the voltage the higher the current draw and the lower the flight times.
Even with LiFes I use a regulator and run at 5 volts. Plenty of power and lots of flying time.
Also, a little easier on the servos.
Good Luck,
KW_Counter
Old 11-12-2012 | 06:14 AM
BarracudaHockey's Avatar
6v rated servos work perfectly on 2 cell A123's so no need to add a component that can fail if you dont have to.
If you want to run straight 2S lipo you either need servo's made for that such as Savox HV (there's others) or run a regulator.
The recievers will be fine, most of them will run happily up to 9v or so.
As to the increased power consumption, its pretty small, testing has showed in the 5 to 7 percent range.
