 Balancing Act >
Balancing Act
Balancing Act
Old 09-15-2003 | 03:34 AM
Default Balancing Act
I am having problem balancing my plane I have checked the manual and have followed it but, it does not describe how to balance the plane left to right I have done tail to spinner. any suggestion would be appreciated.
Regards
Sherpa
Old 09-15-2003 | 04:08 AM
flyerdarren's Avatar
Default RE: Balancing Act
have someone help you. pick up the plane by the spinner and the tail (this is where your buddy comes in) if one wing drops, take note and repeat. if the same wing falls when you pick the plane up again, add a little weight at the opposite wing tip. repeat until the plane balances. Most planes should be pretty close on the lateral balance. so it shouldn't take much. If you can, try to shift batt/rx towards the light side before you add weight. hope this helps.
Old 09-15-2003 | 10:24 AM
MinnFlyer's Avatar
A little trick I do if I'm alone is to set something like a paint can under the spinner. Block it up so that it is just touching the bottom of the backplate. Then, put one finger under the rear fuse, and lift using the can to hold the nose up.
Here's a link to a few balancing tips:
http://www.rcuniverse.com/magazine/a...?article_id=84
