Props?
Old 09-24-2003 | 06:35 AM
Default Props?
Ok so yeah, I'm a newbie...
But a curious one... I see some gorgeous scale models, that are almost perfect but apart from one thing, they only have 2 bladed props? Why aren't there more 3/4 bladed props around? I know u can get static ones but what is the reason?
Cheers.
Old 09-24-2003 | 07:07 AM
MinnFlyer's Avatar
Default RE: Props?
The biggest reason is that our engines turn much faster than full scale engines do, and the props, being smaller, bring the blades closer together. With a 4 bladed prop, each blade gets lost in the wake of the blade before it, therefore becoming much less efficient.
Old 09-24-2003 | 04:35 PM
Default RE: Props?
Ah cool, makes sence now! Shame though, nice 4 bladed prop would look so much better!
Old 09-24-2003 | 07:34 PM
Charlie P.'s Avatar
Default RE: Props?
It's also a bugger to get a multi-bladed spinner or form your own. Most "real" full size multiblade props are also variable pitch to take advantage of the added surfaces. They also add significantly to weight - and therefore torque.
And they cost too much!
