Need help with a spinner >
Old 09-23-2015 | 03:07 PM
Default Need help with a spinner
I have tried every type of force, short of a sledge hammer, to get this spinner on the back plate. How in the world is it done?
Jack
ID:	2121992   Click image for larger version
Old 09-23-2015 | 03:19 PM
Hi Jack,
Make sure the cut out for the prop is large enough. a sharp whack with a rubber hammer should snap it into place.
Calvi
Old 09-23-2015 | 05:40 PM
tacx's Avatar
Jack,
I feel your pain. I picked up two planes that had the same spinner. What a pain in the *****. The only way you will get the spinner onto the back plate is to line up the tabs and then wack the tip with a block of wood. And you have to wack it good or all the tabs may not seat into the pockets. AND, when you go to take them off you have to fit a small screw driver into some slots and pry it off which usually damages the finish.
Who ever designed this spinner had to be on drugs and should be arrested and put away! LOL
I threw mine out after several of the tabs broke off.
Old 09-24-2015 | 05:53 PM
Yes I agree this type of spinner is better avoided, but if you are going to use one, then the "swift whack with a rubber hammer" technique works well.
Old 09-24-2015 | 05:54 PM
Rubber hammer worked like a champ!
Old 09-24-2015 | 06:13 PM
Yeh, you just have to get up the nerve to go ahead and smack it a good one!
Old 09-24-2015 | 06:56 PM
tacx's Avatar
It just bothered me whacking the end of my crankshaft with any thing. If it is an electric it would bother me more.
Old 09-25-2015 | 05:32 AM
TomCrump's Avatar
I'd throw the spinner away and buy one that is held on with bolts.
Old 09-25-2015 | 04:43 PM
Put a small dab of Vaseine on the tabs , works wonders .
