Wall Powered AC Motor
Hello,
Is it possible to have a setup where an AC motor (Ex. QF2827 2600KV Brushless Motor) is powered by a 110v wall outlet instead of going through an ESC controller and a battery?
I'm looking to build a test stand for one or more motors where there will be a switch to spin the motor 100% forward, 50% forward, 50% reverse, and 100% reverse.
Since the wall outlet is already AC, I imagine all I need is a single-phase variable speed controller, but all I can find are industrial controllers.
Is my solution too simple?
Does anyone know of any product that might work for me?
Thank you,
Vincent
Thank you,
Vincent
Hello,
Thank you,
Vincent
Thank you,
Vincent
Stick with using an ESC and a servo tester to signal the ESC, and power it with a simple AC to DC power supply unless your really bent on reinventing the wheel ........
