Futaba 16IZ question
So I got a hold of a Draco 2.0
PNP model I have the reciever that came with my Futaba my main and only question is can you set up reverse thrust?
All i see is the Spectrum ESC that it comes with the 100amp connects to a spektrum controller to engage it.
but when if you use a futaba reciever and the 16IZ will i still be able to use reverse function? if so then how?
Thanks! Christian
Thanks! Christian
My Feedback: (27)
I have two Dracos, and I also only fly futaba systems. I ended up removing the AR637 spectrum RXs and selling them. I didnt see any way to hook up the reverse, but I didnt really want to spend too much time investigating this. I just slow down and use flaps.
