Retracts Question >
Retracts Question
Retracts Question
Old 01-28-2023 | 02:28 AM
Default Retracts Question
Hi all,
Might be a stupid question,
Can I run retracts on one channel through a Y cable ?
The problem I’m having is one wheel go’s up and one go’s down.
Also, can I use a 3 position switch ?
cheers.
Old 01-28-2023 | 02:32 AM
BarracudaHockey's Avatar
If one goes up and one goes down you're probably going to have to run them on their own channels.
You can run them on a 3 position switch but it will act like a 2 position switch. They either go up or down when the signal crosses a specific threshold and run until they shut off.
Old 01-28-2023 | 02:44 AM
Thanks for that reply
No instructions apart from a picture diagram, am I wrong in thinking it’s a Y cable ?
Old 01-28-2023 | 02:52 AM
Just turn the offending servo around 180 degrees or put the servo arm off the other side of the servo.
Old 01-28-2023 | 05:51 AM
scale only 4 me's Avatar
My Feedback: (158)
Yeah, that picture is wrong, both arms need to be the same direction on the retract servos
Old 02-01-2023 | 05:54 PM
Originally Posted by Holmatas
Hi all,
cheers.
Normally, one retract servo is used for the undercarriage. Connection on servo at 180 deg. from straight vertical line of servo arm.
Old 02-04-2023 | 02:31 AM
All fixed thanks, used separate channels, cheers.
