 LT40 Wing Joining >
LT40 Wing Joining
LT40 Wing Joining
Old 12-02-2003 | 09:40 PM
Default LT40 Wing Joining
Does this wing require fiberglassing together? If not is it recomended?
Thanks!
Old 12-02-2003 | 10:18 PM
Kenny R's Avatar
Default RE: LT40 Wing Joining
I would fiberglass it if it was mine.
Old 12-02-2003 | 10:19 PM
You can put a fiberglass strip over the wing joint and
use thin Ca to glue it after you epoxy the wing. This method does make the joint stronger.
But its not a must. The wing will hold just fine if you epoxy it
together under normal circumstances. Now i use a fiberglass
strip on every wing joint just because i put all my planes through the
ringer. LOL
Old 12-02-2003 | 11:21 PM
cappio777's Avatar
<<On my best Rev. Jesse Jackson's voice>>
If you wannit to lasss, you must fiberglasss!
Old 12-03-2003 | 08:16 AM
MinnFlyer's Avatar
If the plans don't say to do it, it's not necessary. That choice was already made by the engineers that designed it.
PS If it's an ARF and the wing is covered, don't bother.
Old 12-03-2003 | 04:19 PM
If I remember correctly, when I built mine, they included a fiberglass strip and the instructions called for fiberglassing the halves together.
Old 12-03-2003 | 05:17 PM
i bought the arf version and just epoxied it together. crashed it once and probably 200 flights to far and no problems with the wing
Old 12-03-2003 | 08:50 PM
I'm getting the kit and if it comes with a strip great! If not I'll probably add one as I like to over build just a little. That is a big wing and I don't want it coming apart! Thanks for all the great advice!
Old 12-04-2003 | 01:33 PM
Spokeman,
The kit version comes with a strip of fiberglass, and yes, I would recommend that you use it, top and bottom. Just per Instructions.
Bob
Old 12-04-2003 | 01:42 PM
spokman,
Over building is fine just remember not to add to much weight while over building.
The quickest way to turn a nice flying plane into a dog is to make it heaver then neccessary. Most kits provide a weight range for the finished product try to stay within that range...
Old 12-04-2003 | 04:58 PM
You are right about heavy planes flying like dogs! In fact I'm going to lighten anything up possible without effecting structural integrity. I want to avoid that tail heavy problem some people are encountering. No way am I putting any lead in my plane for balancing!
Old 12-04-2003 | 07:46 PM
You'll find that the LT-40 has a lot of lift with that big wing. A little extra weight is not going to bother it, but Crashem is correct.. Don't put any extra weight into this plane unless you have to..
Bob
