 Check out this link about Flapperons >
Old 12-10-2003 | 08:31 PM
Default RE: Check out this link about Flapperons
CafeenMan,
No thanks, I have had enough interviews this week. Trying to negotiate a contract really blows.
Old 12-10-2003 | 09:24 PM
ORIGINAL: southern_touch9
CafeenMan,
That's cool. Eventually I'll find a worthy opponent.
BTW - Flaperon has only one 'p'
Old 12-10-2003 | 09:50 PM
gus
ORIGINAL: CafeenMan
Now for a whole new debate ....
Seriously, it has 1 P.... aaawwww shucks. Better change my normally precise writing.
Thanks for the BTW.
SouthernTouch ... do you have a phone or a cellphone?
gus
P.S. Is he still smiling .....
Old 12-10-2003 | 09:53 PM
I wont argue about that (b/c thats how it should be spelled) but I will say that Mike McConville spells it with two P's in his article on the Funtana.
Old 12-10-2003 | 11:37 PM
Just goes to show you, you don't have to spell well to fly 3D.
Dennis-
Old 12-11-2003 | 01:58 AM
  #31
Hey Gus, are you a lawer? I'd have you argue my case anyday. Any come backs have been lame in comparison. Cafeenman has a bit of a go but sorry no prises for second. BTW, I thought there was 2 f's in caffeine.
Old 12-11-2003 | 02:01 AM
  #32
ORIGINAL: john flynn
There are
Also a 'z' in prizes.
Old 12-11-2003 | 02:31 AM
  #33
Heh heh, thanks mate. Kind retards , John.
Old 12-11-2003 | 10:04 AM
  #34
Not saying you guys are wrong about the spelling but Im not the only cat on the block who doesnt spell it right.
"Set the elevator channel at the master, and the flap as the slave (you're already using flapperon mix for the two aileron servos, right)."
- Mike McConville
"hey...I can tell you what I use flapperon and Spoileron mixes for...:
Flapperon: I use flapperon for very tight loops and of course I use the flaps along with a mix of down elevator as the nose tends to pitch up as the ailerons are dropped. To perform tigth inside loops, when the elevator goes up, the ailerons go down and you get a tight loops and vise versa for a outside loop.
Spoileron: Spoileron is used in my case with smaller planes and I have seen Mike McConville use it on his 46%TOC Ultimate. This helps the wings from rocking.
Inverted Harrier uses down elevator and the ailerons pitch downward also.
Right side up Harrier uses up elevator along with up ailerons. This is to prevent from more wing rocking I believe and to keep the plane more stable.
I don't know if you already know this, but I sure hope it helps.
see ya later
dan
_________________
Dan Loris
www.duralitebatteries.com
www.cactusaviation.com
3W Power
http://www.suburbanrcbarnstormers.com/impound/"
Old 12-11-2003 | 10:23 AM
  #35
It doesn't really matter. I was just having a little fun with you.
Old 12-11-2003 | 06:06 PM
  #36
Please look at this link for a definition of flap or flaps. http://www.macquariedictionary.com.a...t/slang-f.html Nowhere does it mention aerodynamics. Perhaps the r/c fraternity has borrowed the term "set of flaps" from a comparative source. I can see a likeness, especially the extended and drooping ones. Kind regards, John.
Old 12-11-2003 | 06:26 PM
  #37
The mind boggles at the concept of a set of flaps fitted to an R/C plane according to the definition given in the Australain dictionary of slang....
Old 12-11-2003 | 06:45 PM
  #38
Now thats a defintion that I like!!! Maybe I will start playing around more with the flaps.
Old 12-11-2003 | 07:24 PM
  #39
gus
Now-now .... the moderators will get in a flap if they catch up with this....
gus
Old 12-11-2003 | 07:25 PM
  #40
cappio777's Avatar
Oh no, the flaperonis are back!
Old 12-11-2003 | 08:27 PM
  #41
Surely the moderators aren't wowsers. For a definition of wowser see http://www.macquariedictionary.com.a...t/slang-w.html Kind regards, John.
