Breaking in Max-40 LA
IL
I am new to the hobby, and I have been building my first plane which is the Great Planes PT 40 trainer. I have the Max-40LA engine with a 10x6 prop. I have never broken in an engine before and I don't want to screw it up so I would appreciate any info how how to do it correctly. The kit came with a nylon (I think) adjustable motor mount and it has screws to hold the engine in, I was wondering if I should use a bolt and nut instead of the screws or do they hold fine. Thanks for any info you might have for a beginner.
The motor you have is very reliable and needs very little in the way of break-in. (It's in the owners manual.) I have the very same motor in my plane. I just put it all together and ran about a tank and a half through it with the standard prop. Vary the speed from idle through full throttle and run it just a touch richer than normal. That's it.
As for the motor mount, I don't know exactly what you have but I'd feel better with bolts and nuts. Make sure that the nuts are the captive type and/or you use a drop or two of Lock-Tite on the threads. You don't want the vibrations to loosen your motor. It is a good idea that you do the same to the muffler bolts too.
Good luck.
Good luck.
Not much to add advise wise that already hasn't been said EXCEPT, Top off a fresh gallon of fuel with about 8 ozs of CASTER OIL, especially with a plain bearing engine. These engines are very trouble free and don't need any break in procedure except put a 10-4 prop on and run just slightly rich. Be aware that as the engine breaks in you will need to open the needle to compensate for the improved compression [HP] that you've got. A 10-6 could help cook the engine sooner if you don't have the high speed mixture just right, and the 10-4 won't work the engine as hard.
