LT-40 ARF WOW!!
LT-40 ARF WOW!!
Hello all-just getting back into r/c after a few years off. I just got my LT-40 ARF in the mail today and I have to say that I am very impressed! Elevator and rudder have all the hinges preinstalled-just add thin ca, and ailerons and wings have all the hing slots cut, torque rods are done. Wings are now bolt on with steel threaded inserts-no messy rubber bands! Light foam wheels are also now included. Way to go Sig! I already know it is a teriffic flying airplane as I built the kit a few years ago and was foolish enough to sell it. If you need a trainer, don't hesitate. At the price they sell it for-its a steal!
MA
RE: LT-40 ARF WOW!!
Cool.
Just to be sure, check the hinges anyway.
On my Goldberg Tiger II, about 1/2 of the preinstalled hinges were tilted, and all of them were the Bad Hinges. (Goldberg provided weird hinges for the plane. I used the Jet Hinges that were also included.) I think Sig has good hinges though.
My Feedback: (8)
IL
RE: LT-40 ARF WOW!!
I recently built the LT-40 ARF as well and was also very impressed. I previously built one from a kit which I lost in a mid-air with another plane. The guy I tangled with felt so bad about the crash he bought me the ARF as a replacement. Not many people would do that!
For those looking for a trainer the bolt on wing is a huge plus over any trainer that uses rubber bands in my book. The rubber bands were the only thing I disliked about the old plane so the new version is now even closer to being the perfect trainer. Some may argue that rubber bands are necessary on a trainer since it is likely to be involved in a crash but I don't see the extra time in setup and breakdown being worth the minimal damage that may be saved by using rubber bands.
The LT-40 ARFs are built in China and the final product they produce is nothing short of superb. I believe the wing bolts were added in a recent "freshening" of the design by Sig. The ARF went together very easily and the instruction manual is perfect. A good instruction manual is important on a plane like the LT-40 since it is often a flyer's first plane.
A great engine on this plane is the Thunder Tiger .46 Pro. It is every bit as good as an OS .46 FX and costs about $50 cheaper!
I can strongly recommend the LT-40 ARF and the kit.
Banned
RE: LT-40 ARF WOW!!
I don't see rubber bands being an advantage on a trainer either. On my Xtra EZ 2, if I only use 6-8 rubber bands the wing will shift forwards. Mostly because I'm doing crazy bad habit hairpin turns learned from my simulator FMS. If I put 12-14 rubber bands on it, the wing doesn't move on the fuse, but what's the difference? Might as well be bolted on, and it would sure be a lot easier to prep at the field. - Joe
RE: LT-40 ARF WOW!!
Thanks for the heads up on the hinges. I will double check them all before I ca them in. I also plan on making it a tail dragger. I had no problems landing my fourstar-just deadstick problems with my ST-45[:@]. Not to worry, new OS AX is in my possesion and going on the LT-40. Anyone want to buy a ST-45 for cheap? Engine is in very good condition-have instuctions and original box, was made in Italy. Would take LA-46 in trade. Good deal if you are one of those guys who is good at tuning those things.
RE: LT-40 ARF WOW!!
Just a thought here. If you fly from a grass field then you may want to go to larger tires than what comes with the plane for better ground handling. For an LT40 I would go with the light weight type and go with 3" for the mains and 2 3/4" for the front tire. [8D]
RE: LT-40 ARF WOW!!
If you liked the way it`s built, wait until you fly it, you`ll love it forever. Ours has an .46FX, flies like a dream. If you fly off grass, follow Fastsky advice on tires, we had to do the same to avoid the prop from dragging on the grass during taxi. Good luck !
KY
RE: LT-40 ARF WOW!!
Nice Glad you like the plane. We have one that flies at our club and i like the way it is designed. its also a floater and the first time I was at the field the owner took it up and i was standing beside it and the owner just handed over the controller. Man was it easy to fly.
RE: LT-40 ARF WOW!!
Ice-man, I converted ours to rubber band wing mount to save time in the long run when teaching my kids, and it has paid for. I have always recommended SIG products, and my all-time ever favorite fun-fly-do-it-all-never-get-old airplane is the Incredible SIG Kavalier. Well, sounds like I work for SIG, but I don`t, I just feel like I owe them because their airplanes last so long that I sometimes feel like that.
RE: LT-40 ARF WOW!!
I have one too. Love it. I used an os46fx for power and it balanced perfectly with no weight. I have about 3 gallons through ot this summer. I increased all the throws and it flies like a new plane-more aerobatically.
1 Post
RE: LT-40 ARF WOW!!
ORIGINAL: Fastsky
My Feedback: (175)
IL
RE: LT-40 ARF WOW!!
I have a older LT-40 ARF, Great Plane, Bad Elec Wire. Just rebuilt the fus, Love it. I would like to convert it to lose the rubberbands, they stink in the cold. Anybody have any plans or great Ideas?
RE: LT-40 ARF WOW!!
1 Post
RE: LT-40 ARF WOW!!
ORIGINAL: goplaneman
As for the TE, it looks like they've just stuck on two ply plates where the nylon bolts go through. Inside the fuse there's a ply plate with blind nuts....
