CLIPPED WING CUB
I would recommend that you go with a plane that is purposed designed as a trainer. There are many of them. If you are not into building there are several good arf's that will fit the bill. From hobbico the avisatr,Nexstar,superstar, from SIG the LT40 arf and there are many others. If you are into building your trainer the SIG LT40, GreatPlanes PT series, the tower trainer, the golderg Eagle 2, protege and there are others. I would go to your local club and hobby shop and see what they use for training and go with that setup. It will make working with your instructor easier because he will be inimately familar with your plane and its setup. The SIG clipped wing cub is a intermediate plane and will probably be a handful for a beginner.
