 question on building LT-40 >
Old 01-07-2004 | 10:06 AM
Default question on building LT-40
I am currently building my first plane, a Kadet LT-40 kit. I have only run into one problem. This past weekend I installed the landing gear block. Everything looked fine when I did the test fit, but when I glued it I noticed that there was approximately 1/16 inch overhang (out of the bottom of the fuse) Guess I just wasn't paying enough attention when I test fit the piece. My question is, will there be any problems if I sand the piece down flush with the fuse and cut the slot deeper?
Old 01-07-2004 | 10:31 AM
Spaceclam's Avatar
Default RE: question on building LT-40
i don't think it has to be level with the fuse at all.
Old 01-07-2004 | 10:40 AM
I agree, it shouldn't hurt anything to leave it 1/16th below the fuse, but if you'd prefer to sand it down that would be fine too.
Dennis-
Old 01-07-2004 | 11:17 AM
My Feedback: (197)
I agree with the other posts. You are ok with i he block below the fuselage and if you feel like sanding go for it.
Old 01-07-2004 | 11:25 AM
If it won't cause any problems I will probably leave it as is. Will this make the bottom of the fuse more difficult to cover?
Old 01-07-2004 | 08:35 PM
Mine turned out the same way. I'm adding Dubro fiberglass gear to mine so I sanded it smooth. I would probably sand it smooth any ways just to have a nice finish. How did your wing go together? I can tell you that I hate folded plans and won't be getting another kit with them unless I really want that kit..
Old 01-08-2004 | 03:14 AM
mstroh3961's Avatar
Hi the cure for folded plans is using an iron to smothe out the creases. NOTE TURN OFF THE STEAM! Then make a trip to KINKOS and make a duplicate set to build over.
Old 01-08-2004 | 08:47 AM
My wing went together fine. The only other problem I had was with a warped aileron, but it seems I was able to get all the warp out before I cut in the hinges.
