 prop nut? >
prop nut?
prop nut?
Old 03-12-2004 | 09:11 PM
Default prop nut?
ive just finished a tufflight 4d and installed an aluminum prop nut. with my other planes my starter turns CCW to start. if i do that with the prop nut it unthreads. dont tell me ive been running my other planes the wrong way and nobody noticed. i did start it today by hand, but is this what i have to resort to? btw CCW is looking at the prop from in front as im starting.
Old 03-12-2004 | 09:45 PM
My Feedback: (16)
Default RE: prop nut?
The nut should be tight enough where the nut should not come off.
Tighten the nut tighter.
Old 03-12-2004 | 09:51 PM
FlyingMonkey's Avatar
Your engine is running the right direction. I use a alum prop nut also with a CCW starter. Just make sure that the nut is tight enough and you should not have a problem. Like Geistware said.
Old 03-13-2004 | 01:05 PM
Ditto on the 2 above posts. I have a Saito 120 with a prop nut. It never came loose on me. Just be sure to tighten it down good. All will be fine.
Mark Shuman
Old 03-13-2004 | 04:44 PM
Ultimate99's Avatar
[b]You got it right steener, You have to spin and start the engine CCW, I think every internal combustion model airplane is designed and timed to run CCW. Otherwize you would have to use a pusher prop. If you have the fox spinner nut that comes with the deluxe 4D you should use a nice piece of 5/32 X about 8" music wire to tighten the nut. And be careful the engine doesn't get too much fuel in it causing liquid lock, (flooding) you can bend a con rod if you use a strong starter. Take out the glow plug and clean it out first.
Old 03-13-2004 | 05:52 PM
thanks everyone for the info. i thought i was doing it right but, then i started second guessing myself. i feel kind of silly asking this ? seeing its my third plane. just thought i was missing soomething. thanks again
steener
