SEAGULL PC-9
I am new at this and trying to assemble a pc-9. The nosegear steering cable flexes terribly when turning the nose gear, which makes the rudder servo bind. Also I am not impressed with the control rods for the tail feathers with the wooden dowels. They don't line up with the control horns and I wonder if a set of semi flexible cables might work better? The manual even talks about bending them if needed. As I indicated earlier I am fairly new at this, but I am not impressed at all so far with this model's quality. So far the throttle cable is the only one to work properly
rene
rene
I have no experience with that model, but I have a couple of general thoughts on your problems.
On the nosewheel, how much travel are you trying to get from the nosewheel? You really don't need much throw at all, most guys set up their nosewheel at first for way way too much travel. Coming in on the servo horn would cause the nosestrut to rotate less, and therefore the bend would be reduced. (I'm assuming the bend causing the binding is between where the pushrod exits the fuse and where it attaches to the nosewheel stearing arm?)
About the pushrods, the old wood dowl is the tried-and-true way to do pushrods that many of us did first. I agree, it takes a bit of messing around to get it worked out. It's not uncommon for that kind of rod to make a bend right before exiting the fuse, then another bend back in line with the control arm. Not right-angles, just a gentel curve to get outside the fuse.
If you want to replace those kinds of pushrods with the plastic or metal flex rods or cables, you can. But you have to make sure the outter sleave is properly supported all down the length of the fuse. That means setting up bracing or drilling holes in formers and glueing the sleave in place way back inside the fuse. It's easy before covering, but really hard after the fuse is covered. If you only support the rod at the ends, it will likely flex in flight, which will not be good.
Yes you are correct about the binding point. it does that next to the fuselage side just before thr servo arm. it is thin wire and it seems to flex a lot for even a small amount of nosewheel turns. I may habe to reconsider the cables as you indicated the amount of work required to support the rod housing as far as the tail surfaces go.
