Measuring Throw: Inches/cm To Degrees
RE: Measuring Throw: Inches/cm To Degrees
Most of us don't bother. We use the T.L.A.R. principle (That Looks About Right).
In other words, pull back on the stick, if the elevator goes up, you're in good shape. If it barely moves, you need more, if it moves a LOT, you need less.
Once you fly it, you can decide whether or not you want to change it.
Banned
Typical trainer throws would be about 20 deg up and down elevator, 20 to 25 deg up on the ailerons and less down than up. (but not necessarilly differerent... its just better if it is different) 30 deg each way on rudder. 5 deg each way on the nosewheel. (less is better.)
Those throws will work for any typical trainer model. The reason you want a very small nosewheel deflection is it is VERY sensitive. The best way to sett it is use the hole closest to the servo arm retaining screw (at the servo) and the hole furthest from the steering block at the nosewheel. You will be amazed how tight the airplane will turn on the ground with a very small movement of the nosewheel.
Take the inverse sin (arcsin) of the throw divided by the width of the elevator or aileron at that point, inches or cm, either, but be sure both measurements are in the same units. (Inverse sin, after performing the division.) Measure carefully, errors can compound to large differences.
Edit for clarification.
FHHuber, its not for a trainer but for a 3D model, I just thought this would be the right place to post.
Jim Schwagle, Thanks although I thought about using math. I guess its the only way.
Banned
For a 3D model... the same throws will be OK for test flying and getting used to the model
When you get into some of the advanced 3D maneuvers you will want as much as 60 deg throw (some will go all the way to 90 deg... but more than 60 is essentially useless.) each way on ailerons, elevator and rudder.
