 Aluminum Spinners  !!!!!!!!!! >
Old 05-27-2004 | 02:47 PM
TNRabbit's Avatar
Default RE: Aluminum Spinners !!!!!!!!!!
Four strokes are especially torquey (torqueish? torqueful?) and harder on a spinner.
I think a lot of the problems with the ate-up spinner has to do with whether you have a silicon or rubber cone in it...
Old 05-27-2004 | 03:44 PM
MikeMc's Avatar
Do the aluminum spinners weigh more? I don't own an electric starter so no issue messing up the plasic spinners.
Old 05-27-2004 | 06:10 PM
To davidinmi,
Many thanks for the help, but DB7260 is P51 shaped, not P40 shaped. Better luck next time!!
Cheers,
Tel
Old 05-27-2004 | 07:25 PM
Pull the starter away from the spinner. Get it spinning so it has a running start. Start the engine and add stripes to the cheap plastic spinner.
That's why I CHARGE my stuff before I go to the field. Never had that problem, even in sub-freezing weather.
Dennis-
