R700
Old 06-18-2004 | 09:14 PM
Default R700
I have a JR r700 reciever. When I plug in the rudder channel the servo twitches and the throws are jumpy. I tried all the other channels and different servos and it seems to be just that channel. Is this a common thing? Is it ready for the trash? Any advice is appreciated thanks.
Seth
Old 06-18-2004 | 09:30 PM
TPierce's Avatar
Default RE: R700
did u check the battery?
Old 06-18-2004 | 10:14 PM
Default RE: R700
I agree, check your battery. I have the R700 in my LT40, and it performs flawlessly.
Old 06-18-2004 | 10:55 PM
TNRabbit's Avatar
Default RE: R700
If the battery is OK, I'd contact JR. Has the rx been in a crash? If so, send to back to JR for a check -up.
Old 06-19-2004 | 12:01 AM
Default RE: R700
It was in a crash about a year ago. But it worked fine up until today. I am charging the bat in hopes that is all it is.
Seth
Old 06-19-2004 | 12:07 AM
TNRabbit's Avatar
Default RE: R700
Anytime an rx is in a crash you should have it checked. There can be internal problems waiting to bite you during flight. Is your plane worth it?
Old 06-19-2004 | 06:01 PM
Hircflyer's Avatar
Default RE: R700
Does it do it with the transmitter on? If not its okay, I have three and they all do it with the transmitter off, but are solid with the transmitter on.
