 Remote and Engine Question for 300S >
Old 06-30-2004 | 10:57 AM
EAP
Default Remote and Engine Question for 300S
OK, I need some advice,
I have an plane with the JR quattro, I'm starting to think of my next plane and my next remote.
I have decided to go with the JR 6102, But not sure if I should get the same channel as my quattro? What are the pros and Cons to having the same channel besides the obvious, You can fly two planes with one remote and you limit yourself to one channel at the field...... are there other issues I should think about before I make my purchase?
Second Question:
I'm planning to buy the Seagull 300s ARF (63 inch wingspan)
I guess I would like to here some opinions on the plane from those of you who have it and what is a good engine for this plane? The LHS said if it recommends a .61 Then put a .75 or bigger in it or I will be wanting more power. What do you have in your 300S and how does it run? What would you recommend?
Thanks for all the advice!
Michael
Old 06-30-2004 | 11:06 AM
wings's Avatar
Default RE: Remote and Engine Question for 300S
If you get the same channel and one of the tx's takes a crap on you then you can still fly both planes....
I think you've pretty much stated the pros and cons. If you get a different channel you can fly wich ever plane has the open frequency at the field. Do you have to share frequencies often? If you don't I would say to get the same channel.
Old 06-30-2004 | 06:08 PM
EAP
I think I'll go with the same channel.
But I still nedd some help with my plane choice and Engine!
Michael
Old 06-30-2004 | 07:29 PM
Either a Thunder Tiger .61 pro or Tower .75
both are power houses
