 Engine Brand >
Engine Brand
Engine Brand
Old 07-12-2004 | 06:04 PM
Default Engine Brand
I would like to purchace a .71 engine , can anyone recomend a good brand name and web site to purchase from. At Tower, there is Fox,GMS,O.S. , Super Tiger, Thunder Tiger and Tower Hobbies.
Tower Hobbies .75 Ball Bearing ABC Schnuerle is the cheapest....is this engine any good or should I stay away from it?
So many decisions....so little time
Qwazzy
Old 07-12-2004 | 06:17 PM
a65l's Avatar
My Feedback: (17)
Default RE: Engine Brand
What's engine going on?
Andy
Old 07-12-2004 | 07:00 PM
Campy's Avatar
ORIGINAL: qwazzy123
Qwazzy
From your statement I presume you are looking for a 2 stroke.
OS and Thunder Tiger are excellent engines and you will not go wrong with one of them. The GMS engine is also a very good engine AND extremely powerful, but it does require more "fiddling" with than OS or Thunder Tiger to get running right.
Tower engines are made by GMS but with a different carb. I have had the Tower 46 engines. With the 46's I have had, the power was excellent and the transition and idle were quite good. The bad news - they will not shut off with the transmitter. Perhaps 1 out of 5 engines will shut off with the transmitter. I don't know if this carries over to the 75 or not. To me, not being able to shut the engine down with the transmitter is a MAJOR safety hazard and an ACCIDENT WAITING TO HAPPEN. Other users of the Tower 46 have also reported poor idle and transition in addition to the shut down problem.
I have not heard any reports of the GMS not shutting down with the transmitter. Paul McIntosh
[email protected]
is the person to contact about the GMS engines. He has quite a bit of experience with them and can tell you the ins, outs and quirks of them.
If you want to go with a 4 stroke, get a Saito. User friendly, runs great and sips fuel.
Hopes this helps.
Old 07-12-2004 | 07:56 PM
Either the TT or the Super Tiger would be my choice of those listed. I like the Super better. I have one to go into a Top Flight AT-6 someday. One other that I would reccomend, MVVS. They make a 77 that is real strong. Will put out tons of power on low nitro fuel. Quantum models and Morris hobbies sell them. With a tuned muffler they are an animal. I have 2 40's that are almost as strong as most 60's. Good luck with whichever one you end up with.
Mark Shuman
Old 07-13-2004 | 09:11 AM
Sport_Pilot's Avatar
I don't think OS or TT makes a .70 two stroke. Fox is probably the best on your list, with a lifetime warrenty and great service. The carb problems are fixed. The only problem is that you cannot use more than 5% nitro fuel without modifying the head button. The Super Tigre is probably the next best, followed closely by Tower.
Old 07-13-2004 | 12:19 PM
SST
The Fox is an heirloom engine...Take care of it properly, and it will last longer than you will, and it's American-made.
Old 07-13-2004 | 01:30 PM
8178's Avatar
My Feedback: (17)
The Irvine .72 would be a good choice. The .72 is in a .61 casting so it is space efficient and puts out about 2HP. I have 2 .61s, 2 .53s and 1 .46 and they are all great engines. They are a true ABC engine as well!
Old 07-13-2004 | 01:34 PM
Well, let me put it this way if you want to be a pilot go with OS, other wise you'll be a mechanic and then a pilot.
Old 07-13-2004 | 02:56 PM
Gringo Flyer's Avatar
My Feedback: (18)
I would echo a few of the previous suggestions and stay away from the Tower engine. I love my TT Pro, it runs like a champ.
Old 07-13-2004 | 05:00 PM
ICE_MAN's Avatar
Super Tigre
Old 07-13-2004 | 05:41 PM
mars's Avatar
os os os os blah blah
Read the forums and see who has more problem posts.
ORIGINAL: jucava
Im a pilot and have never had to take apart my TT or ST. They Run hard and strong.
I drive a ford but Im not close minded about Chevy.
Old 07-13-2004 | 09:36 PM
Easy answer FOX!! there is not better engine out there.
Old 07-13-2004 | 09:56 PM
Josey Wales's Avatar
My Feedback: (61)
Super Tiger or TT..
Old 07-14-2004 | 01:23 PM
enahs's Avatar
I would personally go with a Super Tiger 75. I have 4 Super Tigers, 2 75's and 2 90's. Once they are broken-in they are very powerful and very reliable. Tower Hobbies has the 75 for 119 bucks at towerhobbies.com. Can't go wrong with 'em.
Shane
Old 07-14-2004 | 01:51 PM
ICE_MAN's Avatar
Super Tigre and thunder Tiger are simply the bast strongest running engines on the market.... I hated my O.S. engine both in truck and planes Sold them for ST's.... Try one there will be no turning back...
Old 07-14-2004 | 03:50 PM
Ok.....Look like Super tiger 75 is what I am going to get. Does anyone know if you need to get an engine mount for the Sig 4* arf, mine should be coming in the mail in the next couple days.
Old 07-14-2004 | 04:20 PM
raideron's Avatar
Your ST75 should be a good match.. The supplied mount will
work with the 75.. At least it did with 4*60..
Old 07-14-2004 | 05:54 PM
I love my O.S. I haven't had a problem with any of mine
I love them so much I even have O.S. branded on my arm (backwards, be carefull with hot engines )
