 Newbie, need help with Engine >
Old 07-19-2004 | 10:51 AM
Default Newbie, need help with Engine
Killed a Magnum .40 that I had installed on my trainer (old easy fly 40, Hangar9) JB Weld doesn't help, I do have another Old K&B .61, can I use it with my trainer or is it too much??
No money , want to learn, and fly this weekend again, only minor repairs on the trainer needed.
Thank You
Old 07-19-2004 | 01:16 PM
Default RE: Newbie, need help with Engine
How in the hell did you kill a Magnum without completely trashing the trainer??? Most engines will take a hell of a beating before giving up the ghost.
p.s. IMO the .61 is too much for a .40 size trainer.
Old 07-19-2004 | 01:38 PM
Thanks Merlin, I don't know how, just happy it survived, needs lot's of epoxy some weight will be added that's why I tought I could use the .61.
Thanks for taking the time to read my post.
Old 07-19-2004 | 01:59 PM
Campy's Avatar
If the K&B is the BUSHED BEARING type, you should be OK powerwise. The bushed 61s had about the same power as a ball bearing 40 - 46. Don't forget to rebalance the plane. MOST 61 engines like a 12x6 prop, so make sure you have adequate ground clearance.
How did you manage to "kill" the engine ?
JB Weld usually works well. The key to getting it to work/adhere properly is to make sure the surfaces are CLEAN. I recommend using acetone to clean the part(s) and DO NOT HANDLE THEM on the surface to be glued - the oils on your hands can (usually WILL) cause a poor bond. One other thing - use the regular JB Weld. The 10 minute stuff, at best, has only 1/2 the strength of the regular stuff.
Old 07-19-2004 | 07:23 PM
Yea the old K&B 61 was not a real screamer stock. Could be made to run real strong with mods. But you could use it. As someone else said 12-6 and remember to use the left stick. Be sure to rebalance the plane. Good luck with it.
Mark Shuman
Old 07-19-2004 | 08:33 PM
If you're hoping to fly this week, definitely use the 61, just keep the throttle back during manuevers.
Dennis-
