fuel tank size
Here is a silly question.
I have a Carl Goldberg freedom 20.
It requires a 4 ounce fuel tank.
My question is can I use a 6 ounce tank or will that be to heavy?
Thanks in advance for your help.
If you can cram it in there, you can use it. The tank weight isn't going to mess with anything. The weight of the fuel, while non-zero, isn't going to be huge either. I've put in over-size fuel tanks before with no problems.
AL
I agree! The more fuel you can get in there the better. I had a Freedom 20 several years ago powered with an O.S. 26 Surpass. I can assure you the extra weight should be no problem.
What engine are you using for power? I just might build another one someday soon. It sure was a fun plane to fly!
IL
I am going to stuff a 6 oz. slant tank in it just to see what the difference in flight time is.
