Midstar 40 question
I have an old Sig Midstar 40 and lost the instructions to it. I need to reset the control throws and balance it out. Does anybody know the specs on it?
KY
Here you go, from the manual. These are recommended for test flying. No other measurements are given.
Throws:
Elevator - 1/2" Up, 1/2" Down
Rudder - 1" Left, 1" Right
Ailerons - 3/8" Up, 5/16" Down
I couldn't find the CG anywhere, except for marks on the plans. I measured them to be between 2 3/4" and 3 1/8" from the leading edge.
Hope it helps.
Throws:
Hope it helps.
