 Balancing high vs. low wing models? >
Old 11-16-2004 | 06:07 PM
abufletcher's Avatar
Default Balancing high vs. low wing models?
I'm finishing up a Lucky Stik (an "ugly stik" clone) and have a question about balancing. I've been told that you should balance a low-wing plane upside down and a high wing plane right-side up. The stik design has the wing "at the shoulder" and the balance point seems different depending on whether I'm balancing right side up or upside down.
Suggestions?
Old 11-16-2004 | 07:50 PM
JohnBuckner's Avatar
Default RE: Balancing high vs. low wing models?
A shoulder wing aircraft would be balenced rightside up as a high wing is.
John
Old 11-17-2004 | 08:28 AM
CG is in the same place weather the fuse is above or below the wing. Just easier with it hanging below.
Old 11-17-2004 | 08:55 AM
> been told that you should balance a low-wing plane upside down <
There is no such rule. The only matter is in which position the model will be stable when perched on the stand. Models which are hard to keep steady on a stand can be balanced using a sling.
Old 11-17-2004 | 11:20 AM
Thanks for all the suggestions. I balanced it right-side up and it's almost ready to go (just have to set the throws). I had to add a bit of weight to the nose to get it to balance but other options like a larger engine (for further forward placement thereof), relocating the battery/receiver, heavy prop nuts, etc. just weren't available in this case.
The solution: I found a donut shaped lead weigh at a fishing shop and pounded that flat and put it up against the inside of the firewall. The hole fits perfectly around the fuel tank stopper and fuel lines. If I need to add an oz or two more for a bit more of a nose-heavy heavy effect, I'll stick the usual lead weight squares on the firewall.
BTW, I also found some nice lead tape (about 1/2" wide) that looks like it could be good for a number of modeling uses including fine tuning the balance with small bits of scale detailing.
Old 11-17-2004 | 11:59 AM
MinnFlyer's Avatar
If you need lead, here's a handy tip:
Go to your neighborhood Gas Station (One that does tire balancing - or go to a Tire Shop)
Every time they balance tires, they remove the old weights, and replace them with new. The old weights are thrown into a bucket until they are disposed of. Just stop in and ask for a handfull (or two). They are going to throw these away anyway, so they don't care if you want some.
Melt them down with a torch on an old cookie sheet, or frying pan (available at flea markets)
They are even marked with their weight - need 12oz? Melt down two 6's - or a 6, a 4, and a 2
Works great, and they're FREE!
Old 11-17-2004 | 02:11 PM
Fastsky's Avatar
Yep, the tire weights work well. I am into my 3d bucket now! I haven't bothered melting them down. I also cut off smaller pieces from the long ones to use in the wings for lateral balancing. I glue them in with canopy glue because it is vibration resistant. [8D]
