 spinners and APC props >
Old 11-24-2004 | 02:53 PM
RichD's Avatar
Default spinners and APC props
dunno what forum to post this in, so it goes here
I have been using a propnut like the one below ever since I started using APC props because I cant find a spinner that works with APC props without having to dremel it out, which I wont do for saftey reasons.
So, who sells 2" or 2.5" spinners (plastic for weight reasons) for APC props?
Old 11-24-2004 | 06:57 PM
carrellh's Avatar
Default RE: spinners and APC props
SIG spinners www.sigmfg.com are described as "designed to fit APC props."
The Hobbytown USA near me stocks a few of these.
There are 3 "real hobby shops" close to me also, and they do not stock the SIG spinners.
Old 11-24-2004 | 07:01 PM
RichD's Avatar
within an hour, I have 2 hobbytowns, and about 5 hobby shops, guess its time to start calling them all for that spinner type.
thanks for the info
Old 11-24-2004 | 07:59 PM
MinnFlyer's Avatar
And just for future reference, there's nothing wrong with "Dremeling out" a Spinner.
They are designed to fit the smallest prop feasible for that spinner size, so most of us need to open them up a bit.
Old 11-24-2004 | 08:29 PM
jboy381-RCU's Avatar
i use the spinner nut on all my planes...a dubro spinner almost put my brother's eye out...it blinded him for three days...good thing it wasn't a direct eye hit...
john
P.S. he's fine now nut it ended his flying career...i got all stuff,so it worked out good for me...
Old 11-24-2004 | 08:34 PM
ORIGINAL: MinnFlyer
Exactly right. And APC is one of the few manufacturers that will cut your spinner for you. I think it costs about $20, but it's worth it just to avoid the hassle and trying to make the cut-outs symmetrical.
Old 11-24-2004 | 08:59 PM
RichD's Avatar
the spinner nut isnt a problem, but if I replace it with a plastic spinner, the weight differance would be almost what I need to get more tail weight on my magic, instead of adding more lead weight.
Old 11-24-2004 | 10:22 PM
I have been using Higbey Nuts on my magics, I think they are lighter than the dubros. And I also dremel out plastic and aluminum spinners, then balance them on a top flight magnetic balancer. A balanced spinner is almost as important as a balanced prop.
Old 11-25-2004 | 11:24 AM
There is a very good thread in the Tips and Techniques forum on balancing spinners.
Jim
