Gluing foam
WI
Old timer at the field gave me some foam floats
to put on my trainer.I have to balsa the floats and
he gave me a can of Duro all-Purpose spray Adhesive,also.
He said works great and is inexpensive at Wal-Mart.
I havn't tried it yet,but he uses it.
Later...
Later...
Hi!
Polyurethane is good..think it is called "Gorilla glue ". But to cover foam floats with balsa then this metod is best .
Pour out some white glue or aliphatic resin on the balsa sheet that you are going to cover the float with...spread it thin ..let it dry. Do the same on the float. Then when everything has dried...just use your iron to secure the balsa onto the foam float.
But a much better way of having a nice surface is to using Epoxy finnishing resin and 25g-50g glass cloth. Much faster and much more easy to do!
Regards!
Jan K
Sweden
Regards!
Jan K
Sweden
PA
balsa can be atached to foam with double sided tape. its sticker than fly paper& low weight. good for foam wing sheeting .it shoiuld work for the floats ok. once set it will nor come apart.
