 CG test >
CG test
CG test
Old 02-05-2005 | 12:02 AM
Default CG test
To check for center of gravity, my assembly manual says nothing about putting fuel in the tank. I am building an Alpha 60, the tank is in front of where the center of gravity should be. Do you fill the plane with fuel, it's about 12 oz tank.
Old 02-05-2005 | 12:05 AM
a65l's Avatar
My Feedback: (17)
Default RE: CG test
Nope. Fuel tank empty. Yes, the plane will be nose heavy with a full tank of fuel, but you want to ensure that it dosen't become tail heavy as the fuel burns off. So empty tank. Retracts retracted (when you get that far). Should hang exactlly level or just slightly nose down. Tail down is BAD! Nose heavy planes fly badly, tail heavy planes fly once.
Andy
Old 02-05-2005 | 12:19 AM
Default RE: CG test
Thanks.......
Old 02-05-2005 | 10:52 AM
Pilot Chad's Avatar
Default RE: CG test
a65, I am going to go check mine now. lol. I have checked it once but thought it should lean back a bit dont remember if it did or not. Testing mine now...
Old 02-05-2005 | 10:57 AM
Pilot Chad's Avatar
Default RE: CG test
ok, i checked mine again and it is a little less than 3 " back on the wing. Sound right?
Old 02-05-2005 | 03:05 PM
raideron's Avatar
Default RE: CG test
I think the Superstar select MKII 60 CG is at 3&5/8" back from the leading edge
as the starting point...
Old 02-05-2005 | 06:27 PM
a65l's Avatar
My Feedback: (17)
Default RE: CG test
newbtoRC: Not knowing your plane I can't say if 3" is right or not. Either in your instruction book or on Hobbico's website you'll find the CG listed. If your plane balances foward of the required CG, as long as it's not more than 1/2" foward, you'll be fine. More than 1/2 " and you will want to think about moving your receiver battery aft. Get the balance point as close to the CG as you possibly can.
Andy
