 DISASTER!!!! >
DISASTER!!!!
DISASTER!!!!
Old 02-11-2005 | 05:50 PM
Sarges_heroes2003's Avatar
Default DISASTER!!!!
its a disaster!!! I was tuning the engine and was going to go taxi around the yard when DISASTER struck!! the prop came off.
well I have found the prop but the nut and washer thingy is stil AWOL. I took after them with a metal detector but no luck. no findie. well gues ill just have to go to the LHS and buy a sack full.
Old 02-11-2005 | 05:54 PM
bubbagates's Avatar
My Feedback: (32)
Default RE: DISASTER!!!!
One good thing is all your fingers are still there and the prop is not sticking out of your body some where
I'm glad you are OK.
Old 02-11-2005 | 06:00 PM
My Feedback: (9)
aw man if you think thats a disaster I can't wait to read your post when you crash!
Sean
Old 02-11-2005 | 06:03 PM
The "washer thingy" is called a "prop washer" and the nut is a "prop nut". These must be tightened down quite securely. We both know you don't have a LHS locally and no a home depot part won't work(extremely hard steel). You could probably borrow these for the weekend at the field while waiting for shipment from Tower or somewhere else. Did you have a spinner on? It probably would have captured the now missing hardware. Tighten nut with a 4-way or combination wrench. I use a socket wrench, 1/4 drive, myself. Don't want to break or strip anything but must be tight. Be glad prop didn't fly into your face. parts will only cost a couple of bucks and you can research and find at Tower. Gives you an excuse to order more stuff if you want. you know, glue, planes whatever. Good flying this weekend. I'll be here in morning and hopefully have flying weather by lunch time.
Bruce
What kind/size of engine was it again?
Old 02-11-2005 | 06:15 PM
piper_chuck's Avatar
My Feedback: (12)
ORIGINAL: bruce88123
... find at Tower. Gives you an excuse to order more stuff if you want. you know, glue, planes whatever.
Yup, if it was me I'd be tryin to reach that $150 line for free supersaver club shipping, but then when I got there I'd have to get to the $199 line so I could get that $30 discount. An ARF or two is fully justified to save the cost of shipping a couple prop nuts and washers, right?
Old 02-11-2005 | 07:00 PM
bruce,
its a .40 size thunder tiger GP. Good news was that is spun right up with one "spin" of prime but when U try to start it with two or more spins of prim it will just spit it right back at ya. odd, but ok now I know how to do it. I took off the cone and cann't remember why. prolly should put it back on.
Piper_chuck: you are oficially addicted, time to call for help.
Old 02-11-2005 | 07:07 PM
My Feedback: (12)
ORIGINAL: Sarges_heroes2003
Yup you're right, I'm addicted. I feel much better now. Knowing you have a problem is the first step toward recovery. So, now I ask for help! I need a couple props, should I add an uproar ARF and Modeltech ME109 or the GP Shoestring?
Old 02-11-2005 | 07:09 PM
Sarges,
My heart sank when I saw your thread title, and was really happy to see it was just a little lost hardware! [8D]
I have to agree with Piper Chuck, get out that credit card and buy more stuff!
Dennis-
Old 02-11-2005 | 07:18 PM
ohh noes, piper u really are in deep. this addiction cannont be fixed by your self, YOU MUST SEEK HELP!! It is to strong for you to handle alone, and that is where we have gone wrong. trying to right our selves by our selves. go get help, don't run to the flying field. they will just pull you back in. try the court house or some place like that, they usually have some help classes there.
Old 02-11-2005 | 07:24 PM
No, you only need one of each and a six inch wrench. Get that nut TIGHT. Don't be afraid of breaking it, you won't.
Old 02-11-2005 | 07:38 PM
bubbagates's Avatar
My Feedback: (32)
Srages,
Piper_chuck and the rest of us know we need help, if you think we will get it, not on your life and in a few more weeks you'll be the same way.
When I get to the LHS tomorrow I'll look to see if we have the prop washer for that engine. We have a box of small engine parts that is full of needle valves, washers, etc...
I'll PM you tomoorow evening aboutit
Old 02-11-2005 | 07:39 PM
MikeEast's Avatar
PS,, If you threw the prop you might have been too lean. Might want to start it next time with the needle valve 2 or 3 clicks more open. Maybe not,, just something to check.
Old 02-11-2005 | 07:41 PM
Hey thanks bubagates!! that would be so cool!!
Old 02-11-2005 | 09:34 PM
rwright142's Avatar
Does double nutting work?
Old 02-11-2005 | 11:15 PM
don't know if double nutting would work. might try. wouldn't want to put put to much on there cause that would weigh down the engine. might try adding a small flattened area and using it to lock tight the prop nuts. that might work. would any one like to put in some coments on that idear??? purdy please.
Old 02-12-2005 | 12:06 AM
MinnFlyer's Avatar
ORIGINAL: BigNed
Ned took the words right outta my mouth.
CHECK THIS!!! If your engine is running too lean, you will ruin it
Old 02-12-2005 | 12:17 AM
drunkenbushman's Avatar
Man i feel for you, i know to well the anguish a prop nut can cause, i tho had the oppiste proplem, i tightened my prop nut so tight that i could not get it off. I was trying to hand start my new OS .46 La (WASTE OF TIME) and got frustrate so i went to the shop and bought a starter a 12v Battery a nose cone and a few new glow plugs for good measure. When i got home and went to take of my prop i could not get it loose. I was trying so hard that i stripped the nut to a nice circle. Then i had to bright idea to get out the angle grinder and make new flut spots ( not my brightest moment when i look back). That failed to work as i just kept stripping the nut. Well then i decided to just gently grind away at the nut untill it fell off, makes sense right, well that didnt work either, so then i decided id get the hack saw out, cut of the prop, and try and loosen what was left of the prop nut from behind. After hacking of both sides of the prop i was left with the middle bit of the drive sharft with ALOT of cut marks in it but failed to get it off.
i think that had the be the worst day for me when it came to making dumb decisions. i still have the engine wth the middle of a porp on it and a angle grined pop nut. [&:]
Old 02-12-2005 | 08:01 AM
Chuck-
in your condition it is best NOT to make decisions like this. Buy everything and sort it out later. There is no other reasonable choice if you think about it.
Old 02-12-2005 | 02:21 PM
was invited out to a "local" field today. it was not a nice day to fly, but we had an itch that just had to be scratched. the weather soon brought us back to our sences though.
I asked the guys to look over the plane and tell me if any thing needed adjustment or any thing needs work. well some stuff did need to be worked on and that is good now. one thing about the engine, none of the dozen or so flyers at the field used abc type engines. I inquired as to why that was. they told me they didn't like them because they were not sute to the "dorking around" that we usually do at this field. appearantly ABC engines are suposedly only good for wide open throtle only, and not very well suited to the dinkin around type flying that these guys do(and what i want to do). so im thinkin of gettin rid of my abc engine and going with a .45-.50 OS RINGED engine.
The troubles a ABC can give you just don't seem worth it for a sunday flyer.
Old 02-12-2005 | 03:46 PM
bubbagates's Avatar
My Feedback: (32)
Sarges,
I'll argue the statement about dorking around with an ABC engine. Seems to me my OS46AX engines loved to run at any throttle setting for as long as I wanted Now ringed engine is always better but not required
I did check the LHS today for the washer and we did not have one. I could order it but you would be just as well off ordering it from Tower Hobbies
Old 02-12-2005 | 04:08 PM
My Feedback: (12)
I'd ignore them and be happy with what you've got. If ABC engines were as limited as they said, they would not be anywhere near as popular as they are. I've got ringed and ABC engines. I've not had trouble with either kind. One of my ABC engines is an OS 25F ABC that I bought in the mid 80s. It runs great all through the throttle range, not just wide open.
Old 02-12-2005 | 04:09 PM
My Feedback: (12)
Chuck-
Good plan. Better go find my credit card and order before my wife comes home.
Old 02-12-2005 | 05:37 PM
A guy gave me a washer and a nut that would work for the engine. they held tight. I can vouch for that. we fliped and fliped that engine over and over (and we really had to bear down on it) and it would go for a little bit but then would be to tight for it to continue. my plane will not idle on the ground with out zooming away, if i turn it down any more it will die (probably from the engine being so tight)
the guys said they have never seen an engine that was so tight from the factory, it was so tight there electric starter would not turn it over untill we had hand cranked it a little. even then it did little good. the only advise they could offer is to warm it up with a covering iron or hair dryer. that might help. me don't know. I think I will still go get a ringed engine though.
Old 02-12-2005 | 08:59 PM
You are lucky the prop was not near when it departed, we had a gent have one come off at the bench and run up his bare wrist and arm. nothing that stitches in the emergency room could not fix. Forget the nonsense about the ABC engines being inferior, you will see at least five times as many of them as ringers at any club event, they start easily and run dependably and are easier to break in. Sounds like you could use some old fashioned help in starting and adjusting the engine and that is not easy to find sometimes. Hang in.
Old 02-13-2005 | 08:53 AM
Was this the case when it threw the prop while taxiing? It sounds to me like you lost the thrust washer along with the prop washer and nut. The thrust washer goes behind the drive hub. ABC engines are perfectly fine and well suited for the hobby, you don't need a ringed engine.
You don't need to double nut a 2-stroke. Just get the prop nut tight.
