reversed caburator???
MS
Is there a way that the carb on a os engine be reversed so that control for it would be on opposite side and it can be done are there any pros and cons.
Don't quite work that way with the throttle valve opening backwards,Your midrange will go south with a lot of other things[
Yes I have tried it[:@]
[8D]
Yes I have tried it[:@][8D]
MS
thanks for the advice went the opposite way had to cut out tube for throttle and nose wheel and drill holes and put new tubes looking at it they glued firewall and some bulkheads backwards
