 Snaproll configuration ? >
Old 02-23-2005 | 08:19 PM
CitatioN10's Avatar
Default Snaproll configuration ?
I got my JR XP8103 and i got the snaprool hooked up , i just want to verify with you guys before i try it out tomorrow
Left alieron up right down
Left full rudder
elevator up
thats what it does when i hit my switch
Old 02-23-2005 | 08:37 PM
tIANci's Avatar
Default RE: Snaproll configuration ?
Errrrr ... what is an Aileron UP RIGHT DOWN?
You can have:
ELE - UP
AIL - LEFT
RUD - LEFT
ELE - UP
AIL - LEFT
RUD - RIGHT
ELE - UP
AIL - RIGHT
RUD - RIGHT
ELE - UP
AIL - RIGHT
RUD - LEFT
ELE - DOWN
AIL - LEFT
RUD - LEFT
ELE - DOWN
AIL - LEFT
RUD - RIGHT
ELE - DOWN
AIL - RIGHT
RUD - RIGHT
ELE - DOWN
AIL - RIGHT
RUD - LEFT
ANything else? Hahahaaa .... seriously, try to give less throw for certain controls and you will see the plane flip over slowly and its a lot more graceful than looking like a drunken bumble bee. Have fun ...
Old 02-23-2005 | 09:08 PM
CitatioN10's Avatar
How would you do it to make the tail flop over the wing ?
Old 02-23-2005 | 09:57 PM
Ed_Moorman's Avatar
That should give you a left upright snap roll. I say should because you need enough up elevator and left rudder to make the plane snap. Fairly large control surfaces and a slightly rearward CG also help.
To do a waterfall or flip-flop, you need a plane with very large controls and 45 degrees plus movement. Fly level, partial power, quickly pull up to vertical, full down and full power.
Old 02-23-2005 | 11:02 PM
CitatioN10's Avatar
WOW thats going to take some practice !! Do you consider the Ultrastick 40 large control surfaces ?
