Trainer/buddy cord
no problem using different frequency. but as far as i know, pcm you cannot use. you need to set both on ppm. i'm not sure why that is but i tried with a pcm tx master, ppm tx student setup and wouldn't work in pcm. only after putting it on ppm did it work
[8D]With Futaba and Airtronics brands the buddy box switch is left "off" and doesn't need a crystal or batterys. In fact its better off to not have them in. JR is a different beast. The buddy box needs a battery pack.
