 Does servo spindle position matter? >
Old 03-24-2005 | 10:05 PM
Default Does servo spindle position matter?
In a GP Stick 60 ARF, three servos are installed in the tray side-by-side, with all three spindles positioned forward and all the servo labels aft. Will the center servo (elevator) lose power or performance if I reverse its orientation so that the spindle is positioned aft and the the label forward? (There would be no change to orientation of the throttle or rudder/nosewheel servos.) Would the performance results differ if I were reversing orientation of an aileron servo with just a short control rod? When and why does spindle position matter? Thanks.
Old 03-24-2005 | 10:13 PM
CitatioN10's Avatar
Default RE: Does servo spindle position matter?
I wouldnt think so myself , on my Ultra stick i have the center servo the completely opposite way . As long and the part moves i would say your good to go
Old 03-24-2005 | 10:20 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
It won't matter at all as long as your control rods are ran long enough to get to the new postion, or shorter if you move the other way. When I lay out my servos in a fuselage I usually stagger the postion of the servo arms to help avoid any conflict between servos.
Hope this helps
Old 03-24-2005 | 11:15 PM
twistr's Avatar
You'll love the way this plane flies. My brother has one with a Saito 100 and mine has a Magnum 91 FS. What are you going to put on yours?
Old 03-24-2005 | 11:48 PM
And actually with shorting up of the control rod you generally get a better set up. Shorter pushrods and connections usually mean stiffer and tighter control linkages. Not so much slop.
Old 03-25-2005 | 12:17 PM
Thanks all for taking the time to reply. Will be using an old Enya 61 2-stroke for now, will replace with Saito 91 soon.
