 Pull pull or push pull >
Old 04-09-2005 | 11:13 PM
Pilot Chad's Avatar
Default Pull pull or push pull
I will be biulding my four star soon and I was wondering what would make pull-pull better than push pull. So could someone give me some reasons to get pull pull or not to get it.
Chad
Old 04-10-2005 | 07:04 AM
Default RE: Pull pull or push pull
I wouldn't bother with it on a 4*, just use the hardware that comes with the kit (or ARF).
Pull/pull is often lighter than a control rod; it can actually give you more precise control, because the servo is always pulling the control surface, pushing on it under flight loads can cause a slight bend in a pushrod; and pull/pull is just cool.
Hope that helps.
Dennis-
Old 04-10-2005 | 07:28 AM
exeter_acres's Avatar
I'm using the stock hardware on my 4* 60 and there have been no problems... My rudder has been enlarged by about 1.5" and a counterbalance added, and I have had no problem.....
I't will KE the whole length of the field
But a Pull Pull is cool...
a push pull would add a bit of weight I should think
Old 04-10-2005 | 10:02 AM
Pilot Chad's Avatar
ok, I think i will end up upgrading to pull pull later. Can someone show me some pics of the pull pull systems while they are set up on a plane?
Old 04-10-2005 | 10:58 AM
Campy's Avatar
Here is a link to Alan's R/C page http://homepages.ihug.co.nz/~atong/ There is A LOT of good info there. There are several articles on Pull-Pull just a little ways down.
Old 04-10-2005 | 11:24 AM
hookedonrc's Avatar
Here is a few of pics of my pull pull set up on my Ultra Stick Lite. It may not help since is it not inside the fuse, but then it might just be what you are looking for.
ID:	256508   Click image for larger version
ID:	256509   Click image for larger version
Old 04-10-2005 | 02:29 PM
Pilot Chad's Avatar
ok thanks hooked.
It looks like this plane may come sooner than i thought. I will be on a box for a while though
