After the crash >
After the crash
After the crash
Old 10-01-2002 | 12:32 PM
Default After the crash
On a seperate thread, I discussed how my Cub crashed on its second flight.
As stated I bought it used, in flying condition, therefor I didn't check out everything.
Now, as I'm rebuilding it, I've measured the distance from wingtip to rudder, and found that I have 3/8" difference over this lenght. Bearing in mind that the lenght is approx 30", will this make much difference to its flying performance.
THanks for any replies.......
Old 10-01-2002 | 03:12 PM
on the cub I don,t think you will notice it.But it together and go fly,times awasting.
Have a goodun,John
Old 10-01-2002 | 11:31 PM
If the wing tip to rudder measurement is off it's going to cause a "yaw" effect on the airplane. Especially if you have dihedral. 3/8 of an inch is most likely not going to cause a noticable problem, but keep in mind that's what going on when your wing is not "square". If you have dihedral then any yaw will lead to a roll. So be careful to adjust the right control surface when trimming out the aircraft.
Old 10-06-2002 | 03:19 AM
Hypter's Avatar
Hi I just measured my trainer, it is about 1/8 of an inch off... I havent flown it yet so I dont know if it will be fine, but will this cause any problem?
Old 10-06-2002 | 11:27 AM
no go fly that sucker,times awasting,if it sits to long the termites will attact,also thumbs will go numb!!!
Have a goodun,John.
Old 10-25-2002 | 03:25 AM
freeonthree's Avatar
Terrell Flyer is right. Go flying before your thumbs forget how. After you trim that sucker, you won't be able to tell the difference. I wish all my planes were only off 1/8"
Dennis (Red Bluff,ca)
Real airplanes have 2 wings and round motors..............
