 question about an electric motor i found >
Old 06-09-2005 | 11:14 PM
txaggie08's Avatar
Default question about an electric motor i found
I get no responses when i post in the electric forum so i came here........
I found in my box of junk a little rc motor called an epic 27 it looks like it has two magnets and im pretty shure its brushed. does anyone have the specs for this engine(im looking but i cant find the two batt version). does anyone know if it would be sutiable.....possible witha gear box..... to use it on a Electric aircraft? i would realy like to think the little bugger would run my seniorita conversion, but i dont know.
Thank you for any and all info you can give with this.
Thanks and Gig'em
**edit** this actualy might be a little brushless motor. i think i found one like it on ebay. i wrote the seller and im hoping he tells me what i need to know as far as specs
Old 06-10-2005 | 04:44 PM
txaggie08's Avatar
Default RE: question about an electric motor i found
well i know now its a 27 turn 14 degree(whatever that is) motor........
anybody wanna venture a guess wether it will work(its also brushles i beleive). if so, direct drive or geared ?
Old 06-10-2005 | 09:43 PM
E-Mo's Avatar
My Feedback: (12)
EPIC 27?
is this a motor used in rc cars on/off road?
spec27 turn stock motor?
got a pic?
Old 06-10-2005 | 11:32 PM
txaggie08's Avatar
yes its for off road r/c cars. its a stock 27 turn motor. its alos brushed (i misread what i thought it said).
ill work on a pic....its a bright silver can with flattend sides
Old 06-12-2005 | 06:06 AM
could it possibly be a slot car motor. Flat sides and timing lead me to that. oups you said it was from an off road didn't you? silly me.
isis
Old 06-12-2005 | 01:37 PM
txaggie08's Avatar
yeah it was from some small(maybe a foot total length) truck
Old 06-13-2005 | 10:44 AM
BuzzBomber's Avatar
Is this what you have? [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGSZ1&P=7]EPIC stock motor[/link] Typical stock brushed buggy motor for 6 cells. You could probably use it with an 7-8 cell sub-C nicad/nimh pack and a "speed 600' gearbox around 2.5:1 with something like a 10x6 prop. It should be limited to around 20 amps, and could probably fly something like a .15 or lightly loaded .25 size plane. I'm assuming you wanted to use it for a plane?
