OS 40 FP Prop shaft
You can buy spinners from Tower Hobbies, that have aluminum backplates -- these are thin enough to fit your engine. Another alternative is to use a thinner washer under the prop nut.
This is supposed to be the crank for your engine if I looked it up right. Included are the specs for you to compare to yours.
http://www2.towerhobbies.com/cgi-bin...I=OSMG4536&P=7
From there you can make some decisions.
Hi!
What you do is to have someone make you a spinner aluminum nut with a flange that protrudes into the prop, that way it centers the prop and you can tighten the prop firmly.
I allways use these prop nuts on my sport airplanes.
I can make one for you in any shape you like.
Regards!
Jan K
Regards!
Jan K
