 SERVO PROBLEMS >
SERVO PROBLEMS
SERVO PROBLEMS
Old 06-27-2005 | 01:56 PM
Default SERVO PROBLEMS
MY SERVOS JIDDER AND SHAKE ONCE I TURN THE PLANE ON.
WHEN I MOVE THE TRANSMITTER CONTROLES THEY DON'T SEEM TO RESPOND????????
ANY IDEAS GUYS?
THANKS MICHAEL
Old 06-27-2005 | 02:47 PM
Default RE: SERVO PROBLEMS
Are the Tx & Rx batteries fully charged?
Old 06-27-2005 | 02:50 PM
My Feedback: (16)
If it jitters when you turn it on the it may be a TX problem.
Make sure your crystal is fully seated and the battery is charged
Old 06-27-2005 | 03:24 PM
You may be so close that your transmitter is "swamping" the receiver(just too much signal). Back away a few feet (maybe 5) and see if that helps. I'm assuming the antenna is fully up and not physically touching any part of the plane or rx antenna. Your rx antenna is fully deployed and not coiled or wadded up somewhere in the plane.
Has this radio ever worked or is it new to you? Make sure rx crystal is same channel as tx is marked. Are you transmitting in proper mode? PPM or PCM
Are the radios new or used and if used are Tx and Rx the same brand?
Old 06-27-2005 | 03:39 PM
ptulmer's Avatar
Sounds like the TX is in PCM mode with a PPM receiver! Alot of computer radios can do both, but are shipped with the cheaper PPM receiver. Your post is kinda vague. Without more details.....
Old 06-27-2005 | 08:50 PM
thanks for your response. iturned on the tx
it is set /or has pcm displayed. i am pulling out the manual
again. i'll try to find out what it should be and how to set it
thanks michael
Old 06-27-2005 | 09:15 PM
Timthetoolman1's Avatar
What is the receiver, FM?
Old 06-27-2005 | 09:18 PM
HELLO BRUCE,
THANKS FOR YOUR RESPONSE.
I CHECKED THE PCM/PPM SETTINGS
THE TX WAS ON PCM, I RESET TO PPM AND IT LOOKS FINE.
I'M A HAPPY BOY AGAIN.
THANK YOU
MICHAEL
Old 06-27-2005 | 09:21 PM
THANKS EVERYONE,
IT'S FIXED. THE Tx WAS ON PCM.
I SWITCHED TO PPM AND ALL LOOKS GOOD.
THANKS
MICHAEL
Old 06-28-2005 | 07:47 AM
A couple of us made the right guess. All that counts is that it works and the repair was FREE. Now get it all together and get to flying it. My guess is that you are new at this so be sure to get an instructor. Join a club too and meet a bunch of new friends.
Bruce
Old 06-28-2005 | 08:52 AM
ptulmer's Avatar
And before you feel too bad, I was pulling my hair out two weeks ago with the same problem. That's why it jumped out at me. Four years in the hobby and still making booboo's.
