What Is The Proper Break-in For A Irvine .46 Abc Mkiii Engine ? >
Old 10-15-2002 | 06:59 PM
Default What Is The Proper Break-in For A Irvine .46 Abc Mkiii Engine ?
Hi
WHAT IS THE PROPER BREAK-IN FOR A IRVINE .46 ABC MKIII ENGINE ?
HOPE TO HEAR FROM YOU ALL
THANKS
Old 10-15-2002 | 07:33 PM
dant-RCU's Avatar
You might start by just following the instructions that came with the engine.
Dan
Old 10-15-2002 | 08:35 PM
SwampFlier-RCU's Avatar
I have an Irvine .53.
just mount the engine on the plane and make sure that the fuel lines are ok, open the needle valve 1 3/4 of a turn then prime it by turning the prop with the throttle full open, close the throttle just below 1/4 put your glow starter and start the engine.
Once it starts lean the mixture to increase full power and hold for a couple of minutes, then let it down to idle an select your idel speed.
Turn it of and let it cool, the repeat the process but run next time for 5 min full throttle but not overly leas, just a bit on the rich side.
Let *** cool, then refill the tank and start it again recheck the idle and full throttle mixtures, don't let it go too lean leave two or three clicks on the lean side. after you ran the 2nd tank and the settings are ok you can go flying
My .53 starts with a chicken stick (flipped backwards) on the first try.. hope your .46 does so.
They're sweet running engines!!
Regards,
patrick
Old 10-15-2002 | 08:53 PM
Just follow the instructions it came with. I've got a .53, and it's without a doubt the best engine I've ever owned. Irvine makes great engines!
Old 10-16-2002 | 01:17 AM
jettstarblue's Avatar
Default IRVINES AND OTHER ABC's
Hi, I have had an Irvine .40 for almost 12 years, and it still packs a punch, good engine!
ALL ABC engines should be broken in at a wide open throttle setting and at a very rich TWO CYCLE-
A ringed engine should be broken in with the needle set at a FOUR cycle.
Run for 2-4 min. and shut it off. Let it cool COMPLETELY, and repeat. After you run a couple of 12oz. tanks through it, start leaning it out and go fly it. Don't mess with the low end mixture until you have run a half dozen tanks through it, and then only if you have to!
Jetts
Old 10-16-2002 | 03:59 AM
HI
Thanks for getting back to me guys
mjse
