 os 61 muffler question >
Old 08-24-2005 | 11:30 AM
mrbass111's Avatar
Default os 61 muffler question
does the os 61fx come with a muffler gasket. i didnt find one and someone told me that the fx 61's dont use a gasket. anyone know for sure?
Old 08-24-2005 | 11:57 AM
Default RE: os 61 muffler question
It doesn't matter if it comes with one --- throw it away. A gasket will compess under useage and your header bolts will loosen. Use a thin film of red RTV silicone as a sealing surface. Since the OS mating surfaces are very good, you can also just bolt the muffler straight to the exhaust port without a sealer.
Old 08-24-2005 | 12:13 PM
itspuddingtime00's Avatar
I haven't used a gasket. So far so good.
Old 08-24-2005 | 12:15 PM
exeter_acres's Avatar
no gasket on mine
Old 08-24-2005 | 01:10 PM
If you check the part list in the manual, you will not see a gasket.
BTW - be careful with RTV, some of them can be corrosive to aluminum. Could eat away at your muffler and/or engine. The red RTV we have here at work is OK but that doesn't mean ALL red RTV is OK. I have seen full scale a/c parts that were eaten up by RTV in the past.
Old 08-24-2005 | 03:35 PM
Fastsky's Avatar
Thankx for the heads up bruce![8D]
Old 08-25-2005 | 09:41 AM
mrbass111's Avatar
it has to be asked, now what is rtv?
Old 08-25-2005 | 12:07 PM
It stands for: Room Temperature Vulcanizing (elastomer sealant)
elastomer = Any of various polymers having the elastic properties of natural rubber.
Vulcanizing = To improve the strength, resiliency, and freedom from stickiness and odor of (rubber, for example) by combining with sulfur or other additives in the presence of heat and pressure.
In other words, the stuff sets up (cures) into a rubber like material at room temp.
A good site is: www.dictionary.com Just found it myself.
Old 08-25-2005 | 04:25 PM
mrbass111's Avatar
thanks for the lesson, i feel much smarter now. but dont give me no pop quizes next week hehe.
Old 08-25-2005 | 04:28 PM
I had to look it up too. Been too long out of school.
Old 08-26-2005 | 01:05 PM
I have an os61 and there is no gasket or RTV. Just bolt it on and go fly. The bolts won't loosen either.
