flight time
WA
I get between 10 and 15 minutes with a 10 oz tank on a .46. But it will depend heavily on your flying style and where you've got the throttle... wide open or just cruising around at about 1/3 open.
Also be aware that "air" minutes seem much longer than "ground" minutes... I'll fly around for what seems like forever, land, and find out I've only been up 10 minutes.
I just put 18 minutes by the 9C's throttle timer on a .50 with a 10 oz (300 ml) tank at 2/3 throttle. The throttle arm broke loose in flight. That's a loooooong flight.
As mentioned, it depends on how nuch throtte you use, cleanness of drag, richness/leanness of mix.
Figure 15 minutes at least for a "routine" flight. You could probably stretch it much farther if you deliberately try and keep her up and glide a lot. We used to do that in the two channel days.
ORIGINAL: thunderchicken
Hi,
About how much run time can you get out of an 11 oz tank on a 40 size engine?
Hi,
The fuel tank was an 8 oz unit, and I once ran 17 minutes on a tank & landed with power on. Didn't pump much out... and it was a part-throttle training flight, but you get the idea. You'll get plenty long flights with yours, even with a small tank.
Sure wish I'd paid more attention to the battery connector on that trainer....
Dave Olson
