Motors & Capacitors >
Motors & Capacitors
Motors & Capacitors
Old 10-26-2002 | 02:16 PM
Default Motors & Capacitors
I recently bough 4 tamiya high torque gearboxes for a project I'm working on. However the motors that were provided did not come with any capacitors. I want to solder the caps on myself but I do not know the proper values of capacitors required. I know a lot about electronics so all I need is the cap values or their ranges.
Old 10-26-2002 | 05:28 PM
A capacitor should be soldered from each motor terminal to the motor case (or ground). A third one goes across the 2 motor terminals. Use a capacitor value of around 0.01uF (this is the most common value mentioned by most of the discussions on interference problems I have seen.)
p.s. - a quick search thru this and other forums for the subject "capacitor" will produce an astounding number of hits. All pretty interesting.
Old 10-26-2002 | 07:50 PM
Anywhere from .01 to .1 uF ceramic. .047 is about the most used value and the ceramic type is important.
Steve
