Receiver question
I just bought a JR XF631 6 channel radio /w surface frequency modification. I want to use the extra channels to control
various features on the car that require an on/off (e.g. Lights) operation.
How does one hook up such a device to the receiver? I assume there is additional equipment required to convert the receiver pulses into an actual on/off state. Any help is appreciated
My Feedback: (12)
MD
You will need an additional servo plugged into the appropriate channel in the receiver. A micro switch will turn / off the lights or other accessory. You will most likely need an additional battery to run the accessory.
EXCAP232
EXCAP232
