Exponentials.....when and why? >
Old 11-18-2002 | 09:09 AM
freeonthree's Avatar
Default Exponentials.....when and why?
I did go to fly today, however, I didn't get a chance to try out EXPO. I forgot to look at the trims on the tx to make sure they were centered. Took off with full up elevator trim, on high rate, couldn't find trim with thumb, figured I would just come back around and land, cut throttle back to idle, had a bit of a tiff with a tree on the way back to the runway on final turn. Anyway, after I fix the lower left wing tip (not bad,could have been alot worse), I will give EXPO a try. I was hit by a sudden gust of stupidity.
Old 11-18-2002 | 11:16 PM
"You're creating a misconception when you say that expo should be used primarily when there is a lot of control throw"
Thats not really what I was getting at. Was never saying thats the only reason.
Read it how you like but that was not my intentions by saying that one reason. This forum debate can go on forever so I'll keep it simple.
"Your Right"
