 .52 or .61 engine for Cox Tailwind Trainer 40?? >
Old 10-06-2005 | 08:58 AM
Default .52 or .61 engine for Cox Tailwind Trainer 40??
Well I just got the Cox Tailwind trainer 40. Workmanship to my eyes(Beginner's) looks pretty good. I got this ARF cause there is a good chance I will have a few mishaps and the cost of the plane will soften these mishaps. The box states 5.5 lbs flying weight and indicates a engine from .40 to .51. But the plane looks pretty large and I think a .40 engine may not be the engine of choice.
So I am thinking of a .61 engine rather than the .51 engine. I need comments on my choice of engine and suggestions of some engines to consider.....one that will have the least noise as possible.
Thank You, Lakeviewjim
Old 10-06-2005 | 09:12 AM
Default RE: .52 or .61 engine for Cox Tailwind Trainer 40??
Jim, the plane might be big, but it's light. Trainers are designed to have a lot of lift (the wing probably looks very big to you). With all of that lift, it takes less power for the plane to fly. A good, ball-bearing .46-.52 should be more than enough power for the plane. A .61 will be considerably heavier, which might give you some balancing issues, and raise the overall weight of the plane, which is something you want to try to avoid in a trainer. Sometimes over-powering a plane is definitely a good idea, but I have yet to see a .40-sized trainer that needed to be overpowered.
Old 10-06-2005 | 10:13 AM
Agree with glowplug. A plainbearing .40/46 will be acceptable, a good BB 40 will be more than acceptable, & a good BB .46 or 51 will be much more than necessary for training. A .61 will be too much -- 60 size engines are notably larger & heavier than 46's.
Old 10-06-2005 | 10:57 AM
MinnFlyer's Avatar
Another vote for a BB46
Old 10-06-2005 | 11:11 AM
The wingloading of your trainer is on 19 oz./sq. ft. That is light. It will do nicely with a BB46. I would recommend a Thunder Tiger Pro46. It is an excellent engine and a great value.
Old 10-06-2005 | 02:08 PM
Thanks a million, I will go with the TT pro 46, All of you have a great day making lots of money...
Jim
