 i need help within 10 mins help!! >
Old 10-08-2005 | 12:43 PM
Banned
Default i need help within 10 mins help!!
my irvine 46 isnt running propperly and wen i throttle up it goes slower and mumbles and sometimes it doesent im gonna strip down the engine is that wise i no what im doing there might be a bit of rubbish in there ore a blockage ive tried every click of tunine and it just doesent help?
pleASE HELP ME ITS GETTING LATE AND IM GOING FLYING IN THE MORNING HELP HELP!
Old 10-08-2005 | 01:07 PM
Default RE: i need help within 10 mins help!!
Hello; I don't know about the 10 minutes - but - Your problem is in the carb. Don't dissassemble the entire engine if your problem is in the carb. I sometimes don't even take a plane to the flying field, just enjoy the other benefits of being with like-monded people. Whereever you fly there's probably someone who has had the same problem with that engine and has performed the cure.
If you showed up at our field with this problem, someone (likely me) would solve it for you. Even if you don't get to fly, you would get your problem solved. I think it's the same in the UK as it is everywhere else I've been.
Old 10-08-2005 | 01:11 PM
Campy's Avatar
It sounds like you have a blockage or air leak in the fuel system.
1. Check your fuel lines VERY CAREFULLY with the engine running. Do you have any air bubbles ? If you do, pull the tank and replace ALL the fuel lines INCLUDING the ones in the tank. Double check the fuel inlet nipple(s) to the carb and needle valve to make sure they are tight. If they are loose, tighten them and put some locktite around the outside to prevent them loosening up and to seal any gasket leaks. Run the engine. If the problem persists go to step 2.
2. Check the spray bar in the carb. Disconnect the fuel line from the needle valve, and with the throttle wide open, blow through the line. Now do the same thing with the throttle closed. If there is no difference in the amount of force needed, the blockage is in the spray bar. Remove the spray bar and clean it in some fresh fuel or acetone. MAKE SURE YOU DO AN EXACT COUNT OF THE NUMBER OF TURNS ON THE LOW SPEED NEEDLE, it will minimize the retuning of the low end.
3. If the spray bar is OK (or it is still doing it after cleaning it ), move to the needle valve next. Disconnect the fuel line from the tank to the needle valve and put some fuel through the needle valve to flush it out. Make sure the connections are tight for the needle valve and fuel nipples.
Old 10-08-2005 | 01:26 PM
rule #1, don't hurry!! i've learned that anytime you hurry with model airplanes you either a) get bit by the prop, or b) crash a plane... next comes the fact that if you don't trust your engine running on the ground, don't take off with it.
what is the history of the engine? has it been broken in? was it running ok before? could be blockage, could also just be really rich.
Old 10-08-2005 | 01:41 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Luke, since you are fairly new to this hobby I wouldn't take it apart. Chances are you are going to cause more problems than you may fix by taking it apart. My recommendation would be to take the plane to the field and let more experienced pilots take a look at it and see if they can find the problem.
Ken
Old 10-08-2005 | 06:20 PM
Cyclic Hardover's Avatar
you needmto find somebody to tune that engine properly
Old 10-08-2005 | 11:45 PM
Agree with everyone, take it to the flying field as is, maybe someone will fix it in ten minutes and then you fly. [8D]
Old 10-11-2005 | 10:48 AM
Banned
no i took it to bits nothing wrong there put it all back together checked the carb and where the needle valve is there was a ball of dust but now it runs fineby the way rc ken i have dismanteled about 20 different engines b4 so i think i no what im doingdont underestimate me
Old 10-11-2005 | 11:00 AM
FLYBOY's Avatar
ORIGINAL: luke21
]by the way rc ken i have dismanteled about 20 different engines b4 so i think i no what im doingdont underestimate me
Yea, it sounds like you have.
Old 10-11-2005 | 11:30 AM
bubbagates's Avatar
My Feedback: (32)
luke21,
If we underestimate you it's because of how you started this thread. You came in here asking for help in 10 minutes or it will be too late. One could assume that since you have so much experience with those 20 engines then you would not need so much help and in such a hurry.
It's like crying wolf if you get my meaning
Old 10-11-2005 | 12:06 PM
Banned
i aunderstand what u mean bubba but i just needed reasurance of what to do because its the newist and most reliable engine i have and i dont wont to muck it up.
Old 10-11-2005 | 12:20 PM
somegeek's Avatar
Maybe you should just be gracious then when you receive assistance on this board. People will be reluctant to help down the road...
Old 10-11-2005 | 12:27 PM
Banned
i am just dont like people who think they no it all underestamating me(not u bruece)
Old 10-11-2005 | 12:29 PM
somegeek's Avatar
ORIGINAL: luke21
Well people can't read your mind to know what you do and don't know. Getting defensive won't inspire them to help you down the road if you're just going to bark at them.
Old 10-11-2005 | 12:31 PM
Banned
i have menshoned quite a few times hat i no wot im doing in recent post JUST NEEDED REASURANCE!
Old 10-11-2005 | 12:54 PM
bubbagates's Avatar
My Feedback: (32)
Easy gent's....he has his help, He has his engine problem figured out, so now it's time to lock this thread
Old 10-12-2005 | 08:44 AM
Banned
how do u do it bubba?
i wont to but i dont no how?
Old 10-12-2005 | 08:56 AM
RCKen's Avatar
My Feedback: (9)
Luke,
You can't lock a thread. Only a moderator can lock threads.
Ken
Old 10-12-2005 | 09:32 AM
MinnFlyer's Avatar
my irvine 46 isnt running propperly and wen i throttle up it goes slower and mumbles and sometimes it doesent(.) im gonna strip down the engine(.) is that wise(?) i no what im doing there might be a bit of rubbish in there ore a blockage(.) ive tried every click of tunine and it just doesent help?(.)
menshoned = Mentioned
i no wot im doing= I know what I'm doing
newist = Newest
Really Luke, How do you expect people to take you seriously when you won't even take the time to spell or punctuate your questions?
I realize that some of your spelling is "Internet Lingo" but this is not one of your friend's Blogs, this is a serious site dedicated to sharing useful information. MOST of the useful information you will receive here will be coming from people who are way past their teenage years and don't care to be spoken to in such an undignified manor.
You write incoherant sentences, with grossly misspelled words, and then you wonder why people treat you like a stupid kid.
Wise up! Treat us with the respect we deserve and you will be treated the same in return.
Old 10-12-2005 | 10:34 AM
FLYBOY's Avatar
ORIGINAL: MinnFlyer
Ditto!!! burn that into your brain, it will serve you well in all aspects of your life!
Old 10-12-2005 | 12:59 PM
Charlie P.'s Avatar
Wen al els fayls, reed the instrukson manule.
Old 10-13-2005 | 03:59 PM
Luke, It amazes me that you felt belittled or put down by RCKen's remarks. It sounded like good solid advice to me. I too had a bit of a miscommunication with Ken in another thread regarding my experience in one area and my lack of experience in another area. I should have explained my situation more clearly to begin with. He was in no way rude or insulting to me! So I tried to explain my situation to him a little more precisely, with no anamosity or ill-will towards him at all. Quite frankly, I was just greatful he bothered to respond. This is not a chat room on Yahoo. You will find that most of the people here are very nice, as well being quite knowledgable. I soak up great information here like a sponge everyday. So ease up a bit and enjoy the site, that what is here for. Mark T.
Old 10-13-2005 | 05:16 PM
ICE_MAN's Avatar
Charlie,
HAHAHA That's about the 9th thread straight I've visited that I got a good laugh out of your reply! I love it.
Luke,
Check your other thread.. I think I gave you a good bit of advice there from a fellow teen.. The same "rules" apply for the guys on the forum. You remind me of a certain member who USED to be on the forum. I think everyone knows who I'm talking about. Unless your new.
Old 10-13-2005 | 11:11 PM
Looks like Luke may have went the way of Chad.....
Good call, Ice.
Old 10-15-2005 | 07:17 PM
FLYBOY's Avatar
ORIGINAL: 2slow2matter
Good call, Ice.
Maybe on in the same
