 Bi planes >
Bi planes
Bi planes
Old 10-25-2005 | 01:17 PM
Default RE: Bi planes
ORIGINAL: daboosailing
Brittbrat, Ain't it funny how when you correct someones spelling, it can always come back and bite your posterior! Fokker is spelled with two Ks and not Foker as you spelled it! Given I have now corrected you, I have to have misspelled something in this note! Oh well!
Right you are [&:] -- I feel suitably chastised (although you have misspelled britbrat, but I won't mention that one). Lee simply had the wrong company & wrong country.
Old 10-25-2005 | 01:20 PM
The use of the word "Silly" might mean something differant in "Brittish", if so, I appologize!
That would be "British", daboo.
Old 10-25-2005 | 02:12 PM
By "tail crimps" are you referring to the crimps on the pull-pull wires or something else?
I swear I never knew English could be this tough to translate into English.
Think about the poor people for whom this isn't their first language, like Luke. OK, I'm kidding there but you get the idea.
Old 10-25-2005 | 03:22 PM
Right you two clowns, I'm going to spell check every one of your posts and seek revenge.
Then again as long as your picking on each other, it takes the flak of me
Bruce your learning to decipher what I mean now
My description's on engineering reports are worse than my description's of plank parts trust me
Any tips on the fuel proofing?
Old 10-25-2005 | 03:40 PM
ORIGINAL: Lee G
--- Bruce your learning to decipher what I mean now
Aha!!
That would be: "Then again, as long as you're picking on each other, it takes the flak off me".
--- and--- "Bruce, you're learning ------now".
Damned Brits -- can't spell.
I think that we need Luke to act as a translator [:@]
Old 10-25-2005 | 03:43 PM
  #31
ORIGINAL: britbrat
Oi less of this picking on me.
I spelt Focke as Focker. All I did was add an r to the end. And the dead give away it was the German one, was the word Wulf after
You spelt it Foker by dropping the c and still getting it wrong, then blamed me for insulting a whole nation, I'm surprised you never bunged a plague of locusts and a drought or good measure
Old 10-25-2005 | 03:45 PM
  #32
ORIGINAL: Lee G
You're gonna love this. Two (2) F's in "OFF". hehe.
Old 10-25-2005 | 03:46 PM
  #33
Not in your American spell checker on here
Old 10-25-2005 | 03:49 PM
  #34
It didn't show bad because you just happened to come across another real word by accident.
OK guys, let's call an end to the spelling contest as long as we can decode what is meant.
Old 10-25-2005 | 04:27 PM
  #35
Ah shucks, jist as it wus gittin fun.
Old 10-25-2005 | 04:29 PM
  #36
Hey, I'm no moderator. It was just a suggestion.
Old 10-25-2005 | 08:23 PM
  #37
Lee--I'll answer you question.
I'm not sure that cyano is fuel proof. It would certainly not be your best bet. Either paint it with rustoleum (or some equivilent fuel proof paint), or thin some 30 min epoxy with alcohol and paint it on--would be much better fuel proofing than painting on cyanoacrylate!
Old 10-26-2005 | 02:12 AM
  #38
When you say to thin with alcohol. Do you mean something like meths or white spirit?
Thanks Lee
Old 10-26-2005 | 07:18 AM
  #39
Don't know those terms. Best is denatured alcohol. We can get it here at home improvement stores and some pharmacies. It has less/no water in it than isopropyl alcohol does. You will need only a few drops. Use too much and it will not cure properly, it will stay gummy.
You can also use a heat gun to thin undiluted epoxy so it will spread easier.
Either way, use 30 min epoxy. the heat method will accelerate the cure time slightly.
Old 10-26-2005 | 08:33 AM
  #40
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
I try to avoid thinning down the epoxy because if you thin it too much it will never get hard when it sets. It will just remain soft. I prefer to put down the un-thinned epoxy on the area I want to cover then heat it with my heat gun which will cause it to thin out, and while it is thinned I will spread it with an epoxy brush. Be aware that this will accelerate the setting time for the epoxy so you wont' have 30 minutes to work it. I will try to do smaller areas at a time than doing one huge application.
Hope this helps
Ken
Old 10-26-2005 | 08:34 AM
  #41
MinnFlyer's Avatar
As long as you're only using it for Fuel-Proofing you can use any type of alcohol (Isopropyl, Rubbing, Denatured, Everclear, Vodka, etc (Well, ok, the Vodka may be pushing it a little)
Old 10-26-2005 | 08:39 AM
  #42
I understand that Vodka has other useful purposes in modeling.
Old 10-26-2005 | 08:51 AM
  #43
RCKen's Avatar
My Feedback: (9)
ORIGINAL: bruce88123
Yep, it accelerates the drying time of glue. You don't use the vodka in the glue. You drink it while you are waiting for the glue to dry, and before too long it doesn't seem to take very long for the glue to dry!!!!
Ken
Old 10-26-2005 | 09:06 AM
  #44
Or at least you don't care.
Old 10-26-2005 | 12:38 PM
  #45
I now have a picture of some modeler working on a new project, a few glases of vodca later and the wings are mounted.
Then sobering up and finding them on the tail.
Thanks again for the help guys
Lee
Old 10-26-2005 | 12:45 PM
  #46
Never seen the Beech Starship? Canards!
http://www.centennialofflight.gov/es...eech/GA9G5.htm
Old 10-26-2005 | 02:23 PM
  #47
No but I have seen a 140 sized mustang p51 at half price on ebay. Checked the price of the compatable engines and it can stay there. [&o] The importers site only gives a 4 stroke engine size, not two stroke compatable size.
The p51 imo is one of the moast stuning planes to come out of ww2. The look the nuts (translated, means the dogs danglies, translated again means they look very very good )
Old 10-26-2005 | 02:31 PM
  #48
What is the auction link?
Old 10-26-2005 | 03:01 PM
  #49
http://cgi.ebay.co.uk/Flair-Mustang-...QQcmdZViewItem
or item number
6008263868
I have the 50 size here to build. Their kits look well built. Plenty of detail to them.
And wings that wide would look good sticking out the top of my car. Lets just say I drive a german two seat hard top convertable.
I get my heli in the truck and my trainer in the passenger seat.
Old 10-27-2005 | 06:52 AM
  #50
bubbagates's Avatar
My Feedback: (32)
Wow, I missed all the fun. From bipes to Vodka.
I do have one question. What brand of Vodka. I'm thinking Absolute Vodka. That makes all the difference in the world on how long it takes for you not to care how long it takes for the glue to dry
