elec. dual motor question- having problems
MA
hey all, new to this aircraft forum but not new to the site(had a car). ok anyways i have a plane with dual engines and when i have the trim set even(so no props are spinning) then i hit the throttle and one of the engine spins faster than the other. im not sure but i think that they are dual 180 engines. i checked all the connections but there seems to be no problem. also when i have the throttle off and i just hit the left/right the right prop is spinning slower than the left by alot. What do you guys think the problem might be? i was thinking maybe just a falty engine but i really no nothing about it.
thanks for the help Boarding
Banned
it would help to know the plane and manufacturer there is a b-29 electric that uses offset engine speed to make it turn instead of the normal rudder or airleron.aslo no elevater control as engine speed is used to control altitude.
MA
no its just a crappy little plane that i bought for like $80 i just dont know why its doing this. its called a thrilljunkies avenger fx [link=http://www.thrilljunkies.com/rc-planes/avenger-fx-park-flyer.aspx]click here to see it[/link] well there it is its a 3 channel uses the motors to turn and the thing in the back on the bottom(rudder??) to go up and down. i was thinkin of throwin it out but i spent $80 on it and only got it up in the air about 2 times. so i didnt get my money outta it yet. can someone please tell me whats wrong with it. thanks boarding
Banned
not familliar with these but some electrics require that you have the throtle in the low position when turning on the plane then you wait a few seconds before moving any sticks.some have a led that is supposed to light when all is ok.if none of this is the problem could be that the tx is just not returning to zero due to some manufacturing errror in the stick assembly or pots.
MA
i brought the plane to my uncles today he is the plane wiz and he told me that i need a new engine or to get 2 new ones so that they r synced right and then try it. so i will try that and maybe i will get it right...hopefully it will work. and one have any idea on how much a 180 motor will cost. my uncle said not more than $10 per motor. thanks for the help guys
boarding
boarding
