 wing servos >
wing servos
wing servos
Old 10-26-2005 | 06:33 PM
Default wing servos
world models clipped wing cub,my first build in many a year.The problem i have is that the jr servo 537 is to short for the cut out in the wing only two fixing holes sit over the balsa of the wing,do i glue a piece in or put a plate under the servo, which would raise it up maybe to much? any ideas would be most welcome,
Old 10-26-2005 | 07:33 PM
Default RE: wing servos
Glue another stick across the opening so that the servo fits snug--an easy fix!!!
Old 10-26-2005 | 07:35 PM
MinnFlyer's Avatar
Glue a piece of ply under the opening, and then fill in the gap with balsa that is the same thickness as the wing sheeting
