 Removing white residue from covering???? >
Old 11-13-2005 | 08:21 PM
Default Removing white residue from covering????
I used acetone to remove CA from the covering on my plane. It removed the CA, but left a white residue that is almost imposssible to remove. What will remove the white residue without damaging the covering?
Old 11-14-2005 | 09:22 AM
Campy's Avatar
Default RE: Removing white residue from covering????
Pledge (the furniture polish ) will not remove the white, but it will cover it so it is not visible. You will need to renew it periodically though.
Old 11-15-2005 | 10:49 PM
My theory is that whatever you are using to rub off the CA is actually just picking it up and moving it around. I have switched frequently the Q-tip or tissue I was using so that there was always a clean surface to absorb the CA. Usually works.
Old 11-15-2005 | 11:32 PM
pauluk2w's Avatar
My Feedback: (7)
I was going to say i do not love my planes that much, then i noticed you were talking about CA. The best thing you could use has already been mentioned acetone
Old 11-16-2005 | 06:38 AM
krossk's Avatar
My Feedback: (27)
The white film must still be CA. I've been using acetone to remove excess adhesive from the Ultracote and have no problems with hazing or residue. The acetone works so well, I'm almost tempted to see if it will work as trim solvent for the ultracote. I suspect the problem will be it's high rate of evaporation.
Old 11-16-2005 | 07:18 AM
pettit's Avatar
My Feedback: (23)
WD-40 works well, but you then have to take that off with some window cleaner.
Old 11-16-2005 | 07:48 AM
RC-Captain's Avatar
if you use acetone you will be rubbing forever to get all of the CA glue off. It is almost best to just let the glue stay on the plane because it dries clear. ON my shrike I cut the white part out and recovered because it looked so hideous.
