 Help finding a part >
Help finding a part
Help finding a part
Old 01-07-2006 | 10:32 PM
Default Help finding a part
Hey people,
Today I lost my nut that holds my prop. I went to the local hobby shop, but for some reason they couldn't find one. Wanted to see where you all thought I could get it. I have a 46 Thunder Tiger Engine. Please help.
Eric[8D]
Old 01-07-2006 | 10:57 PM
piper_chuck's Avatar
My Feedback: (12)
Default RE: Help finding a part
According to Tower, it's a standard 1/4-28 shaft. This is a very common size. Here's some from Fox: http://www2.towerhobbies.com/cgi-bin...?&I=LXKF97&P=0 . If you look around, you'll find ones from many other manufacturers. You might also be able to find one from a local hardware store.
Old 01-08-2006 | 12:11 AM
This one should work.
http://www2.towerhobbies.com/cgi-bin...&I=LXCT54&P=ML
Old 01-08-2006 | 12:26 AM
w8ye's Avatar
My Feedback: (16)
Most people just go to the hardware store for a 1/4-28.
Enjoy
Jim
Old 01-08-2006 | 09:29 AM
I appreciate all you help people, I am new to the hobby so this helps alot, thanks.
Eric
Old 01-08-2006 | 09:46 AM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
freestyle6883,
Once you find a source for these nuts you may want to pick up some extras and keep them in your flight box. One of Murphy's Laws says that an nut dropped on the ground will immediately roll/bounce someplace that is difficult to see, and impossible to retrieve!!! Having spares can save a flying day at the field if it happens to come off at the field. While rare I have seen prop nuts come off in flight and the spinner, prop, and nut came off and fell off the plane. Pretty much next to impossible to ever find again. So always have spare nuts and props (you can fly without a spinner). Now before you get paranoid about losing it in flight let me say that it's almost always a 4-stroke that throws the prop off, 2-strokes rarely do it.
Hope this helps
Ken
Old 01-08-2006 | 09:48 AM
carrellh's Avatar
If you get the nut at the hardware store, be sure to ask for a "Grade 8" nut versus a common "Grade 5." The grade 8 designation is stronger heat treated steel and is probably what came with the engine.
Old 01-08-2006 | 11:02 AM
Good point carrellh, I've found that when it comes to nuts, bolts, screws & alot of smaller type parts than can be found at your local hardware store, they will be much cheaper than at any hobby shop. Example: a 1/4x28 'prop nut" may be $1.99 at the hobby shop, or 17 cents at the hardware store. Mind you those are not actual numbers, just an example, but you get the idea! I allways check the hardware store first for little things, then if they don' have what I need, I go to the hobby shop.
Mark
Old 01-08-2006 | 02:32 PM
w8ye's Avatar
My Feedback: (16)
Some 2 strokes have what is called a "JAM NUT" on them for a prop nut. They are thinner than a standard nut. I've bought them at the Hardware close to my house.
enjoy,
JIm
Old 01-08-2006 | 08:34 PM
Home depot -- isle 5, right side bin # 36. Just kidding but they do carry 1/4 28's in the nut section. ENJOY !!! RED
Old 01-08-2006 | 11:12 PM
carrellh's Avatar
If you don’t find it at the hardware store, any of these will work
OS Part, $1.89
Fox part, 2 in package for $1.90
http://www2.towerhobbies.com/cgi-bin...?&I=LXG927&P=7
GMS nut and washer, $1.50
http://www2.towerhobbies.com/cgi-bin...?&I=LXEHG0&P=7
Super Tigre, $1.19
http://www2.towerhobbies.com/cgi-bin...?&I=LXFY78&P=7
Tower, $.99
http://www2.towerhobbies.com/cgi-bin...?&I=LXJB32&P=7
Here’s a pack of 100 nuts, that are just as good as any of the above, for less than 3 dollars
http://www.mcmaster.com/
part number 90499A805
Grade 8 Plain Steel Hex Nut 1/4"-28 Screw Size, 7/16" Width, 7/32" Height
In stock at $2.84 per Pack
This product is sold in Packs of 100
